external coil to internal coil?
Old Oct 5, 2005 | 03:32 PM
k24a4kid's Avatar
I'm a Jackass
Default external coil to internal coil?
im posting this for SB tunning... he just switched his extrernal coil dizzy to a internal coil one.. it's started the first time and now it wont start.. does anything have to be done like wireing, ect.?
Old Oct 5, 2005 | 04:42 PM
Rudelude22's Avatar
why would you go from an external to internal that doesnt make sense the external is betteR!!!
Old Oct 5, 2005 | 04:43 PM
98vtec's Avatar
moderator emeritus
Default Re: external coil to internal coil? (turbofienD 04)
what motor? We need more info. Did he do a JDM swap?
Old Oct 5, 2005 | 09:48 PM
high_revs's Avatar
here's the situation:
i have a usdm h22 swap in my 92 si....my dizzy went bad and my friend has a jdm h22 distributor that he doesnt need and gave it to me...so i just like to use this distributor on my motor if that were possible...thanx
Old Oct 6, 2005 | 05:55 AM
high_revs's Avatar
up..
Old Oct 6, 2005 | 08:23 AM
98vtec's Avatar
moderator emeritus
Default Re: (SB tuning)
Isn't the crank angle sensor, etc on the oil pump in the OBDI usdm motors? I know that with my old OBDII usdm motor, the crank angle sensor, etc were on the oil pump and such. The reason i couldnt run the JDM distributer is because it had the crank angle sensor built into it and not on the oil pump. So that would mean, in order to run the JDM distributer you would have to run the JDM oil pump and extend the sensor harnesses to the distributer. But im not sure if this is the same case with the older usdm motor.
Old Oct 6, 2005 | 10:38 AM
high_revs's Avatar
obd1 motors dont have crank sensors @ the crank..i just dunno what year the jdm dizzy is...
Old Oct 7, 2005 | 04:36 PM
high_revs's Avatar
any1?
slowhatchcali
Oct 9, 2015 08:07 PM
Revi
Sep 25, 2006 07:45 AM
N1ghtM0nkey
Apr 30, 2006 11:54 AM
Honda Type R
Apr 8, 2006 02:11 PM
