Polyurethan Ball Joint Boots
I have a set of polyurethane ball joint boots, one goes on the knuckle, one on the upper control arm, and one on the tie rod end. Now the old ball joint boots are held in place with a clip, but the new ones are shaped differently. There is no ridge or any type of provisions for a clip to hold the boot in place.
How does this installation go (no instructions)? Do I just take the old boot off, and slip this on, hoping it gets squeezed down evenly and no grease comes out? That was what I planned to do, just slip the boot on where the old one was and torque down the castle nuts hoping everything stays even without the clips.
Modified by incogNitto at 4:11 PM 10/29/2003
Do I just take the old boot off, and slip this on, hoping it gets squeezed down evenly and no grease comes out? That was what I planned to do, just slip the boot on where the old one was and torque down the castle nuts hoping everything stays even without the clips.-Chet
HTH.
I have done this and if someone else knows how to get the retaining spring on the PE boots pls let me know as there is no recieving groove, I just used a thin lock tie on them, they would probably be allright with just the compression from the LCA.
retriever99
Jan 8, 2020 07:12 AM
incogNitto
Mar 12, 2002 11:05 AM
