clutch keeps grinding sound when...
Old Oct 5, 2005 | 11:35 AM
ej2civic's Avatar
Default clutch keeps grinding sound when...
ok, i just swapped B16A to my 95 EX civic. new clutch, TODA ultra lite flywheel. When I press clutch pedal to way bottom, it keeps grinding sound? what could it be?
Old Oct 5, 2005 | 11:57 AM
amckee's Avatar
Default Re: clutch keeps grinding sound when... (ej2civic)
Throw out or pilot bearing.
Old Oct 5, 2005 | 07:15 PM
ej2civic's Avatar
Default Re: clutch keeps grinding sound when... (amckee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">Throw out or pilot bearing.</TD></TR></TABLE>
throw out??
Old Oct 5, 2005 | 07:17 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2civic &raquo;</TD></TR><TR><TD CLASS="quote">
throw out?? </TD></TR></TABLE>Yes the bearing that goes on the release fork. Number 2 in the pic below..
Old Oct 6, 2005 | 05:15 AM
ej2civic's Avatar
Default Re: clutch keeps grinding sound when... (HondaFanatic708)
But it is brand new AND so is pilot bearing !
help help help
Modified by ej2civic at 6:33 AM 10/6/2005
Old Oct 6, 2005 | 05:35 AM
Gak Attack's Avatar
I had an exedy twin plate put in my evo and it made that grinding noise when I came down from 3-4k in every gear. They said it was the throwout bearing, so thats what im guessing. Is it oem spec?
Old Oct 6, 2005 | 06:41 AM
.Kevin.'s Avatar
Default Re: clutch keeps grinding sound when... (Sticktoyourguns)
put the TOB in wrong maybe..... also did you get the rite flywheel? my friend had a grinding noise and the stupid thing was the wrong flywheel...
Old Oct 6, 2005 | 07:27 PM
ej2civic's Avatar
Default Re: clutch keeps grinding sound when... (Slow_CvC99)
how can flywheel be wrong if it bolted up nicely to block and so did clutch to flywheel?
Havent been driven after angine swap cause Im waiting for my shiftlinkage :l I guess I have to wait it goes away...
Old Oct 6, 2005 | 07:36 PM
coquitlamEG's Avatar
i hate to say it, but if it only happens when you push the clutch in, then the throw out bearing is probably the culprit.
Old Oct 6, 2005 | 07:43 PM
areyoujealous's Avatar
Default Re: (coquitlamEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG &raquo;</TD></TR><TR><TD CLASS="quote">i hate to say it, but if it only happens when you push the clutch in, then the throw out bearing is probably the culprit. </TD></TR></TABLE>
it's opposite of what you said.
if it only happens when you push the clutch in, its probably input shaft bearing
if it only happens when you let the clutch out, then its the throw out bearing
Old Oct 6, 2005 | 07:53 PM
.Ry's Avatar
.Ry
Default Re: (bling bling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bling bling &raquo;</TD></TR><TR><TD CLASS="quote">
if it only happens when you let the clutch out, then its the throw out bearing</TD></TR></TABLE> Not always but he is right. Reguardless you HAVE to pull the tranny. So pull it off and inspect the TO and Pilot Bearing. Check the Clutch Fork and anything else, and if everything checks out sepertate the tranny.
Stoich
11
Nov 6, 2007 04:30 PM
924doorEG
Aug 27, 2007 02:07 PM
crxmex
Mar 12, 2007 06:30 PM
cbmprelude
10
Oct 7, 2006 03:12 PM
1hotvtec
Oct 8, 2003 10:28 PM
