Which pistons use in a ls/vtec?
Old Oct 5, 2005 | 10:28 AM
jfteg's Avatar
Default Which pistons use in a ls/vtec?
Hi,
I'm building a ls/vtec and I want to know which pistons to put in my ls/vtec setup. I wanna use honda pistons. I know that CTR pistons gonna make very high compression but is that to much in the street with 94 octane gaz?
Old Oct 5, 2005 | 10:34 AM
highrevnef's Avatar
Default Re: Which pistons use in a ls/vtec? (jfteg)
if ur gonna run 94 octane u should be fine wut head are u planning on using with ur setup
but if i were u i would just go with type r pistons just my opinion.
Old Oct 5, 2005 | 10:38 AM
SOHCVTECx2's Avatar
ITR pistons is a good choice, plus it also helps you generate a little more torque
Old Oct 5, 2005 | 11:20 AM
jfteg's Avatar
I'm gonna use a ITR head.
Old Oct 5, 2005 | 11:33 AM
Rajin's Avatar
Default Re: (jfteg)
Go with some ITR pistons.
Old Oct 5, 2005 | 11:42 AM
riceball777's Avatar
p30 would be the best for pump gas
i'm runing pr3's in my lsvtec
but in all reality your going to spend about $200 on oem pistons and another $100 on rings. your mutch better off just spending another $150 for some forged pistons
Old Oct 5, 2005 | 12:06 PM
BrooX's Avatar
ITR pistons. Higher compression but....
Old Oct 5, 2005 | 12:25 PM
gsrious's Avatar
dont you people understand that pr3 pistons and p30 pistons produce a higher compression ratio than itr pistons.
anyhow... i list them in order(high comp. to low comp.) for you guys
pct(b16b) > p30(jdm b16a) > pr3(usdm b16a) > p73(itr) > p72(b18c1)
**take note that i didn't show some as usdm or jdm. that's because there are some minor compression differences.
the only differences between the (itr & ctr pistons to the rest) is that they have a coating as compared to the others don't
allmotorek8
Nov 26, 2005 12:42 PM
DC-4-Drew
Jul 26, 2005 06:09 PM
eXplicit
Sep 5, 2004 10:33 AM
granada_sun
Jul 2, 2003 12:52 PM
AzN_Flava
Apr 27, 2002 11:46 AM
