weird noise coming from releasing the clutch
Old Oct 5, 2005 | 09:01 AM
greddytointegrate's Avatar
Default weird noise coming from releasing the clutch
i have a 97 teg gsr...i just recently put in a new clutch and it has about 5,000 miles. When i let the clutch out i feel a weird like grabbing feel (sorry the only way i can describe it)..almost like the pedal is sticking when i release it, however it still is releasing, only with that awkward feeling. Can someone please help me from how i described it ( I know its kind of vague)..thanks in advance!
Old Oct 5, 2005 | 10:23 AM
DC494LS's Avatar
Same problem here. If you release the clutch, it just feels like it gets stuck for a second and pops out. It doesn't happen always, but often, right?
Old Oct 5, 2005 | 10:43 AM
highrevnef's Avatar
Default Re: (DC494LS)
i have the same feeling but my clutch is a stage 2.
Old Oct 5, 2005 | 10:47 AM
temp's Avatar
Default Re: (highrevnef)
did you bother trying to bleed the clutch?
Old Oct 5, 2005 | 11:15 AM
DC494LS's Avatar
A friend of mine told me that I probably need to bleed the clutch, so I called a shop and the guy told me that there is nothing to bleed. That I needed to adjust something.
Old Oct 5, 2005 | 11:50 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC494LS &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine told me that I probably need to bleed the clutch, so I called a shop and the guy told me that there is nothing to bleed. That I needed to adjust something.</TD></TR></TABLE>
WTF? the SHOP told you that your HYDRAULIC clutch cannot be bled? lemme tell you something, NEVER EVER call, go to, use, look at an ad, for that shop ever again
Old Oct 5, 2005 | 11:54 AM
BlackLudeSi's Avatar
Default Re: (temp)
Wow...amazing and that was a shop? Of course you can bleed a hydro clutch, if you have a cable clutch its simply a matter of turning a black ***.
Old Oct 5, 2005 | 01:03 PM
suzawa94's Avatar
Default Re: (BlackLudeSi)
^^very easy to do. just like brakes-pump pedal, hold pedal, then crack the bleed screw on the slave cyl. i just flushed my fluid last week.
Old Oct 5, 2005 | 08:17 PM
Default Re: (suzawa94)
yea basically it just makes like a squeeky noise wheni let it out...its a very awkward feeling on your foot as well; almost as if its fragile...its a very weird noise...would it have something to do with not "breaking in" the clutch correctly?
Old Oct 5, 2005 | 08:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My clutch disc makes a little squeel noise if I engage it slowly, especially if I downshift a gear or two and engage the clutch slowly as I apply the gas. It's been doing that for a long time now, and I have over 70K on my Clutchmasters clutch and flywheel. I still don't know what it is.
Every now and then when I start off in 1st gear slowly, like in a parking lot, it will feel like the car and engine are lagging, and then it will get going. I'm pretty sure the disc is slipping when it does that. But it only does it every now and then, not very often, so I'm not real worried about it.
Old Oct 6, 2005 | 02:52 PM
JS120604's Avatar
Umm, wow!
Modified by JS120604 at 4:03 PM 10/6/2005
Old Oct 6, 2005 | 03:03 PM
DC494LS's Avatar
I will never go to that shop again? Maybe he thought that I had a cable clutch because he said that there was nothing to bleed, that i just had to adjust something.
pcorad
Aug 10, 2007 09:57 AM
imadigitalgod
11
Nov 18, 2006 11:27 PM
turnsignalandy
14
Aug 22, 2006 07:13 AM
RTW DC2R
Jun 7, 2003 12:43 AM
