I need some help.
Old Oct 5, 2005 | 08:24 AM
Exxel82's Avatar
Default I need some help.
Hello everyone, I have a question. I have a 94 civic coupe with a LS/Vtec thats turbocharged. It has JG spec 9.2:1 pistons, JG spec rods, JG cylinder sleeves (open deck design), and a JG block guard, stock b16 head, Drag Generation 3 Turbo kit (upgraded compressor, 57 trim), GSR tranny with ATS LSD. My problem is that when I put the Blox missing link, the car will start but will die like 2 seconds after starting. When I take off the missing link, the car starts and runs fine until I hit vtec or boost cause the check engine light comes on. When I shut off the car, the check engine light goes away, but will come back once i hit vtec again or boost and then the car runs funny. I know the missing link needs to be on the map sensor, but why wont the car stay running if its on. Any help would be appreciated.
Old Oct 5, 2005 | 08:35 AM
wob's Avatar
wob
Default Re: I need some help. (Exxel82)
convert to a gm map sensor...wat computer are u running now... id say buy something like hondatas s200 .. and call it a day.. but people dont **** money.. wat code does it throw
Old Oct 5, 2005 | 08:38 AM
JDM-97CX's Avatar
Are you sure you had the missing link installed right side up?
Old Oct 5, 2005 | 09:49 AM
Exxel82's Avatar
Im using a chipped P28 right now, cause I ran out of money to get the Hondata. I should get it by next month or so. Im pretty sure Im intalling the missing link up correctly. Please let me know exactly so that I can confirm that Im doing it right. I'll try installing it again tonight after work. The side with the O ring should be on top right?
0618turbocivic
May 8, 2006 06:33 PM
FastNFurious
Jun 7, 2003 05:39 PM
integraracer94
May 23, 2002 04:19 PM
Cyber ITR
Nov 2, 2001 09:55 AM
