B16a2 into a 1997 Civic
Old Oct 4, 2005 | 10:20 PM
Novtecdohc's Avatar
Default B16a2 into a 1997 Civic
I swapped a B16a2 motor into a 97 civic dx... I used the Full obd2b Engine harness(motor 99 SI).
The Car runs good and Vtec engages and everything but the speedo and the tach doesnt work... I went and bought the plug that was missing since i was using that 99-00 Si ECU... i figured out why the tach doent work.. fixed it.. but now im stumped of the speedo... help...
Old Oct 4, 2005 | 11:54 PM
hatchi's Avatar
Default Re: B16a2 into a 1997 Civic (Novtecdohc)
that one plug that you are missing has the wiring for the speedo. check the helms manual for wiring.
Old Oct 5, 2005 | 12:17 AM
ruthless013's Avatar
buy a 96-98 EX obd2a harness and an obd2a to obd2b conversion harness from boomslang or the like, and you will have zero problems, and even pass inspection/smog in 50 states.
and then sell the 99si harness.
Old Oct 6, 2005 | 06:50 AM
Novtecdohc's Avatar
Default Re: B16a2 into a 1997 Civic (ruthless013)
I bought the plugh that im missing.. I wired the tach up....A-19 and i wired that speedo up but it work only when the lights are on... C-23... Could someone please help?... Also, if i was missing all the stuff that the A connector has why was my car running without it
Old Oct 6, 2005 | 08:05 AM
sikek's Avatar
buy a 96-98 EX obd2a harness and an obd2a to obd2b conversion harness. everything will run right!
Old Oct 6, 2005 | 09:55 AM
Novtecdohc's Avatar
Default Re: B16a2 into a 1997 Civic (SilverSI)
were can i get a obd2a to obd2b harness.. when i search i cant find it
Old Oct 6, 2005 | 10:27 AM
hondakevin21's Avatar
You can pick up a harness new at http://www.hondaautomotiveparts.com or you can find a couple used ones at http://www.haprecycling.com, http://www.inlinefour.com (you'll have to call for availability) try those out and let us know.
Old Oct 14, 2005 | 01:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruthless013 &raquo;</TD></TR><TR><TD CLASS="quote">
and then sell the 99si harness. </TD></TR></TABLE>
EJtypeR
May 20, 2006 01:16 PM
Grams0wnsyouz99*
21
May 13, 2006 08:17 AM
Grams0wnsyouz99*
Feb 22, 2006 09:56 PM
Grams0wnsyouz99*
Jan 5, 2006 03:51 AM
