Auto meter A/F gauge reading 9-10 LED bars with A/C on!
Old Oct 4, 2005 | 08:17 PM
JDM H22's Avatar
Default Auto meter A/F gauge reading 9-10 LED bars with A/C on!
I have changed the location of the o2 wire, the ground (3 times) and I have the power ran to the fuse box by the dead pedal.( I even ran it sraight to the battery to check but same thing). It runs like 1-2 LED bar with nothing on and no load. 3-4 bars under load. 5-6 with lights and 9-10 under load with A/C. I know they are not supposed to be 100% accurate but this sucks. Is there anything I may have overlooked during the install? Thanks
Old Oct 4, 2005 | 08:34 PM
sharkcohen's Avatar
Default Re: Auto meter A/F gauge reading 9-10 LED bars with A/C on! (JDM H22)
Sounds like you have it wired wrong.
Old Oct 4, 2005 | 10:00 PM
PrettyLude's Avatar
Default Re: Auto meter A/F gauge reading 9-10 LED bars with A/C on! (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have it wired wrong.</TD></TR></TABLE>
either that or a bad connection somewhere
Old Oct 4, 2005 | 10:06 PM
JDM H22's Avatar
It would seem like the easy answer but there is only three wires and I know where they go. Could the o2 sensor itself be the problem?
Old Oct 4, 2005 | 10:44 PM
lude_behavior's Avatar
Could be the O2 sensor, i've noticed with a faulty O2 sensor your car will run completely different everyday.
Old Oct 5, 2005 | 06:00 AM
machine4321's Avatar
ground is not best it sould be
youll want to ground it very close to the ecu , i had the same proble of a bunch of led coming on at once and this solved it .
i grounded it to the ecu ground wire about 4 inches back
Old Oct 5, 2005 | 06:20 AM
LudeyKrus's Avatar
Try grounding on an ECU ground wire.
Also, sounds like you may just have the wrong white wire...
hondacivic90zc
Mar 14, 2007 08:07 PM
GSlowR
Apr 15, 2005 11:20 PM
TURBODC4TEG
Dec 19, 2004 07:32 PM
djnikko
Nov 5, 2003 05:44 PM
nortel
Feb 27, 2003 07:20 AM
