gt35r v.s. gt30r
Old Oct 4, 2005 | 04:54 PM
downeyballz's Avatar
Default gt35r v.s. gt30r
how do these two turbos compare in spool charatisitcs, max power, effecincy, streetability?
personal experince would be helpful.
Old Oct 4, 2005 | 04:56 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: gt35r v.s. gt30r (downeyballz)
gt35r - 625 crank hp
gt30r - 500 ish
obviouly the gt30r is gonna spool faster due to its smaller wheels
Old Oct 4, 2005 | 05:12 PM
Default Re: gt35r v.s. gt30r (wantboost)
but how much faster?
my car is build for the street and dd. i just finished re-building the motor (84mm b16) and i think the gt35r might be a little laggy for me. but i already have it.
Old Oct 4, 2005 | 05:54 PM
Turb0Tek's Avatar
The 30r is more streetable then the 35r. Your turbine house will help determine spool time. The 30r choices are .63,.82,1.06. 35r is .63,.82, 1.06, 1.18. I would go with the GT30r with the .63 turbine housing
Old Oct 4, 2005 | 06:29 PM
Default Re: gt35r v.s. gt30r (Turb0Tek)
i already have a gt35r with both the .82 and .63 (havent tried the .63 yet)
does anyone have any experince with a gt30r? dyno numbers on pump gas.
Old Oct 4, 2005 | 06:36 PM
turboEGhatch's Avatar
GT30R is being pushed to tha max at about 550 WHP. GT35R will do 650 WHP leaning on it. There was an ITR on Jeff's boards that made ~450 WHP on pump gas with the 30R.
Old Oct 4, 2005 | 06:54 PM
Default Re: gt35r v.s. gt30r (turboEGhatch)
i have almost 10:1 compression so thats going to limit my psi on pump gas, thats why i might just keep the gt35r because i will make more power on pump.
i have a feeling that the gt30r will be alot more fun on the street.
Old Oct 4, 2005 | 06:55 PM
im not trying to have the fastest car out there. i just want to enjoy driving it
Old Oct 4, 2005 | 08:15 PM
Blazin Civic's Avatar
GT30r all the way. That is what I am gonna put on my stock GSR and then run it onto a built 2.0 gsr.
Old Oct 4, 2005 | 08:16 PM
how useful is a turbo that is in full boost before you hit vtec?
Old Oct 4, 2005 | 08:20 PM
Phil Koury's Avatar
GT35R:
http://forums.evans-tuning.com...=2598
http://forums.evans-tuning.com...=1799
http://forums.evans-tuning.com...=2260
GT30R:
http://forums.evans-tuning.com...=2330
http://forums.evans-tuning.com...=2223
Those are some graphs of the 2 turbos. Both have fairly decent powerbands.
Old Oct 5, 2005 | 08:14 AM
Default Re: gt35r v.s. gt30r (pkoury)
i think because i already have eth gt35r, i will give it a try with my new build, and if im not happy with it get the gt30r andhang on to the gt35 for later. but whatis the diffrence between a gt30r, gt3040r, gt 3071r?
Axel Foley's Avatar
gt35r .63 a/r great for street power on pump imo
Old Oct 5, 2005 | 09:07 AM
D@nnY's Avatar
i did 655 on 28 psi on the T3 35r
Old Oct 5, 2005 | 09:11 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">how useful is a turbo that is in full boost before you hit vtec?</TD></TR></TABLE>
I'm wondering the same thing too...do these guys lower their VTEC x-over or do they raise them? where do they normally have their x-over set at?
Old Oct 5, 2005 | 09:46 AM
Default Re: (D@nnY)
im not tying to make 600+ hp(at least not tight now) its a street car and the power is useless on the street. what size injectors do you need to make that power, i think that will max out my 880's. how much power did you make on pump? whats your set up?
Old Oct 5, 2005 | 10:48 AM
Turbocivic94's Avatar
Default Re: (downeyballz)
Bro just keep the 35r and put the 63 a/r housing on it. When u get use to it then put the 82 a/r back on it and make more power.
Old Oct 5, 2005 | 10:55 AM
Maveric's Avatar
Default Re: (Turbocivic94)
Just slapt the .63 housing on the 35R and
you will be just fine
Old Oct 5, 2005 | 10:57 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Bro just keep the 35r and put the 63 a/r housing on it. When u get use to it then put the 82 a/r back on it and make more power. </TD></TR></TABLE>
Only in the last 700rpms in the top end will this happen, and that is with a pressure ratio of over 2.224
Sorry to be a poindexter
Old Oct 5, 2005 | 11:50 AM
Default Re: (TheShodan)
does anyone have any experince with either of these turbos on a b16?
Old Oct 5, 2005 | 12:14 PM
BoOstedEM1's Avatar
Wow im pretty sure theres alot of people with experience with these turbos.
Old Oct 5, 2005 | 02:02 PM
Default Re: (BoOstedEM1)
so am i so i wish a few of them would post on this page. but im looking for b16 specific
Old Oct 5, 2005 | 02:20 PM
alpha's Avatar
If it were my motor I would opt for the GT3076RLE or GT3076RLS. The GT35R is going to give you a more unwanted lag as it sounds like your power goal isnt over 500whp. If it were over 500whp I would opt for the GT35RLE or GT35RLS. Good luck.
Old Oct 5, 2005 | 03:27 PM
Default Re: (0x64)
what is the diffrence between a le and ls?
Old Oct 5, 2005 | 03:42 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">what is the diffrence between a le and ls?</TD></TR></TABLE>
Different compressor covers.
- E
A/R: .60
Inlet: 3"
Outlet: 2"
- S
A/R: .70
Inlet: 4"
Outlet: 2.5"
&lt;Edit&gt;
And the L designates water cooling.
&lt;/Edit&gt;
