Motor lag
the check engine light comes on but only after i have been driving the car for about 30 mins.then the car idles up and down.But it doesnt bog when its doing that.I have a p30 ecu.
um.. i think the code is either reading 7 or 17. I have stock mounts so i dont know if maybe the timing jumped a tooth due to vibration. Another thing is that i have an obd 1 obd2 conversion harness.would the o2 sensor cause the check engine light to come on and make the car idle like that.
7 is throttle position sensor and 17 is vehicle speed sensor. make sure the connectors for the map sensor and tps sensor are on the correct ones. can cross connectors are the same. you might just need to adjust the idle air screw to fix idle.17 can cause vtec not to engage. check for damaged wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blcivsi »</TD></TR><TR><TD CLASS="quote">7 is throttle position sensor and 17 is vehicle speed sensor. make sure the connectors for the map sensor and tps sensor are on the correct ones. can cross connectors are the same. you might just need to adjust the idle air screw to fix idle.17 can cause vtec not to engage. check for damaged wires.</TD></TR></TABLE>
REALLY!? the VSS code can prevent vtec from working?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n-line4 »</TD></TR><TR><TD CLASS="quote">
REALLY!? the VSS code can prevent vtec from working?!</TD></TR></TABLE>
uhhh do you even know what the computer runs off of to run vtec?? vtec oil pressure switch and speed sensor.. it will not engage vtec if the car is NOT moving
goinslolsv
Mar 23, 2013 11:47 AM
90civic-ZC
Nov 21, 2011 06:45 PM
