What type loctite to use on manifold to turbo studs??
Old Oct 4, 2005 | 12:25 PM
crex23's Avatar
Default What type loctite to use on manifold to turbo studs??
I'm putting together my turbo CRX (finally!) and I was wondering if there is a certain type loctite I can use to keep the studs in the manifold from backing out? I was gonna just use bolts but I've heard studs are better. I've also read loctite will burn off as high as exhaust temps get.
Please shed some light on my loctite dilemma
Old Oct 4, 2005 | 12:38 PM
project dc2's Avatar
Default Re: What type loctite to use on manifold to turbo studs?? (crex23)
loctite will just melt. you might want to try some hondabond. is what i heard i never tried it myself though.
Maveric's Avatar
Default Re: What type loctite to use on manifold to turbo studs?? (project dc2)
high temp locktight
Old Oct 4, 2005 | 03:52 PM
NJIN BUILDR's Avatar
Default Re: What type loctite to use on manifold to turbo studs?? (Maveric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maveric &raquo;</TD></TR><TR><TD CLASS="quote">high temp locktight</TD></TR></TABLE>
The high temp loctite is only good to 450 degrees.Safety wire works well.Jet nuts work well when you can find them.They have a small steel tab that locks against the threads.They are not effected by heat.
Glenn
Old Oct 4, 2005 | 04:02 PM
MAKK Performance's Avatar
Building cars/Breaking records
Default Re: What type loctite to use on manifold to turbo studs?? (NJIN BUILDR)
i used some hi temp antisieze on mine which was recomended from a friend,, never had any problem after that , i know it sounds weird but it works
Old Oct 4, 2005 | 04:05 PM
Finland's Avatar
I use antiseize on everything exhaust related. The studs are backing out because they aren't torqued properly. Double nut the stud, then torque it down first.
Old Oct 4, 2005 | 04:38 PM
Chris F's Avatar
Default Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">I use antiseize on everything exhaust related. The studs are backing out because they aren't torqued properly. Double nut the stud, then torque it down first.</TD></TR></TABLE>
If you don't double-nut, and you use antiseize, and you track your car, every bolt will come out.. ask me how I know
So, double nut what you can, use lockwashers (anyone have comments on this)..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The high temp loctite is only good to 450 degrees.Safety wire works well.Jet nuts work well when you can find them.They have a small steel tab that locks against the threads.They are not effected by heat.
Glenn</TD></TR></TABLE>
I've heard good things about those aircract locknuts (jet nuts referenced above?) Where do you buy them?
Also, when you say safety wire, do you mean drilling a hole in the nut/bolt head, and wiring it to something fixed so it can't turn at all? This was recommended to me but damn that seems a bit complicated and a lot of work.
Then again, fixing engine fires because your exhaust leaks is a lot of work (or cash) too.
Old Oct 4, 2005 | 05:24 PM
B18EG6's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Ive used the jet nuts firsthand and can certainly vouch for them. I didnt use them on an exhaust however, mine were around a 1/4" thread I believe.
I dont however know where to get any of these, I used them on a payload I built at my internship this summer. I did a search on Mcmaster but it yielded nothing.
Anyone know where to get them?
I googled 'aircraft fasteners' and this popped up
http://www.aircraftfast.com/nuts.htm
The kind I used were the ones to the right, in the rightmost picture
Old Oct 4, 2005 | 06:22 PM
I've had dirt bikes over the years that had them stock.Mostly Hondas and Yamahas.I wish I remember the exact applications.If any one knows a motorcycle parts guy you may find some metric ones.
Glenn
BongoBennie
Engine Machining & Assembly
Jan 29, 2017 07:50 PM
Sprockets
Dec 4, 2011 07:15 PM
slowcrxsib16
Jul 4, 2006 09:56 PM
JDMB20TDA
Welding / Fabrication
26
May 11, 2006 06:33 AM
espanol
Jul 22, 2003 02:40 PM
