loosing water
Old Oct 4, 2005 | 10:32 AM
turbo_b16_ex's Avatar
Default loosing water
every 4-5 days of driving i have to put probable 30 ounces of water in my car. I cant find any leaks. doesnt smoke. no water in the oil. im puzzled help me
Old Oct 4, 2005 | 10:35 AM
komat's Avatar
Default Re: loosing water (turbo_b16_ex)
headgasket
Old Oct 4, 2005 | 10:41 AM
but i have no leaks.....
Old Oct 4, 2005 | 11:02 AM
komat's Avatar
Default Re: (turbo_b16_ex)
you wont be able to see if its leaking unless you pull the hard off.
doublejz's Avatar
possibly an internal leak from the headgasket
Old Oct 4, 2005 | 11:03 AM
jameskersten1's Avatar
Default Re: (doublejz)
you just asked about an oil leak too, I am betting on Headgasket
Old Oct 4, 2005 | 11:08 AM
JDM-EJ1's Avatar
Default Re: (jameskersten1)
Sounds like a headgasket to me.
junior40er's Avatar
haha dude same thing happened to me. Your head gasket is blown and needs to be replaced asap. If not your car will overheat and mess up your block. Headgasket is cheap. the expensive part is installation but if you have mechanical skills is can easily be done by yourself. Hint, check you oil and see if it looks deluted.
Old Oct 4, 2005 | 12:10 PM
Default Re: (junior40er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">haha dude same thing happened to me. Your head gasket is blown and needs to be replaced asap. If not your car will overheat and mess up your block. Headgasket is cheap. the expensive part is installation but if you have mechanical skills is can easily be done by yourself. Hint, check you oil and see if it looks deluted.</TD></TR></TABLE>
you mean mess up your head right?
Old Oct 4, 2005 | 01:05 PM
violence_hero's Avatar
overheating will mess everything up.
Old Oct 4, 2005 | 01:23 PM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">
you mean mess up your head right? </TD></TR></TABLE> well im pretty sure head was damaged by my piston where nearly welded to the block and block got a hairline crack for overheating then getting water on the hot block. by the way people dont ever wash your engine after driving cause it might crack your block.
Old Oct 6, 2005 | 01:15 PM
well i can do the head gasket myself. Ive done them 6 times before with all my previous set ups. Its just that its never done anything like this before which was blowing my mind. I dont see it smoke are anything. I get a little puff of sumtin when i rev it up and let off the gas but thats all i see. It save up for a head gasket though. Btw does anyone know where i can get a knock sensor for cheap? Every place ive heard wants nearly a hundred dollars. thanks.
Old Oct 6, 2005 | 01:17 PM
tdo's Avatar
tdo
look into your radiator cap and see if theres any oil in there. or do a compression test and see if you see bubbles in the radiator with the cap off.
IBriaIN
Oct 6, 2008 11:00 AM
eg2phosizzle
Dec 31, 2006 03:13 PM
caminSi
Jul 27, 2006 07:52 AM
snt78
Nov 16, 2004 02:52 AM
ithrowpoop
Jun 12, 2003 03:19 AM
