Idle Problem
Old Mar 3, 2002 | 08:14 PM
Type R 702's Avatar
New User
Default Idle Problem
i am experiencing idle problems when engaging the clutch at complete stop in my 2001 civic ex the idle tends to fall close to stalling but than shoots back up to regular idle any ideas what could cause this?
Old Mar 4, 2002 | 07:09 AM
GSRMatt's Avatar
25 Year Member
Default Re: Idle Problem (Type R 702)
Does it cycle up and down at all?
Try cleaning out the idle air bypass (attached to the side of the TB) with some carb cleaner. Ours gets sticky and does the same thing.
Old Mar 4, 2002 | 02:50 PM
fixhondas's Avatar
Yeah- It's a 2001 civic. Did you just disconnect the battery? The 01 civics have a "new" ECU that has an EPROM in it that can be updated- for some reason these things take a long time to learn how to idle if power is removed from the ECU. Changes in weather can cause the same thing. Or you might need your base idle adjusted- take it to the dealer- it should be under warranty.
RinzEG6
Nov 24, 2014 12:02 PM
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
downshift3r
Sep 30, 2013 06:34 AM
DC2*Integra
Sep 20, 2005 12:51 PM
