headlight burnout
Old Oct 4, 2005 | 06:01 AM
spilla's Avatar
Default headlight burnout
hey guys I'm new to your forum and have a problem. I have a 98 civic ex and the drivers side low beam keeps burning out. It just started happening out of nowhere, I put a new bulb in and it just burns out intsantly. Getting kinda spendy replacing bulbs hoping one will hold up, not to mention the driver side one is a kind of a pain to get to. Any help would be greatly appreciated thanks
Tom
Old Oct 4, 2005 | 06:08 AM
philosofy1's Avatar
Default Re: headlight burnout (spilla)
what type of bulbs are you using?
Old Oct 4, 2005 | 06:12 AM
spilla's Avatar
Default Re: headlight burnout (philosofy1)
Multiple kinds.. blue ones, clear ones, expensive ones and cheap ones. Is there a specific kinda that might be better?
Old Oct 4, 2005 | 06:18 AM
philosofy1's Avatar
i had the same problem w/cheap bulbs (nokya,apc) i would either use o.e. one from the dealer, our sylvania's. if you have already tried this, or the problem keep occuring, you might want to take it to the shop and have someone look at your wiring.
if your looking for brighter, our stylish bulbs then i would try raybrig, polarg, piaa, or sylvania(silverstars).
well hope this helps, good luck!
Old Oct 4, 2005 | 06:20 AM
spilla's Avatar
Thanks alot I'll give the sylvanias a try
Old Oct 4, 2005 | 07:19 AM
JDM-EJ1's Avatar
Silverstars are great, you shouldn't have any problems with those!
muddmonky
Oct 16, 2012 08:15 PM
vandeec5
Nov 28, 2004 06:01 PM
D15B_Turbo
Jan 22, 2003 09:29 PM
97teg415
Aug 13, 2002 07:12 AM
puckster02
Mar 11, 2002 07:19 AM
