rebuild didnt start - weird stuff
Old Oct 4, 2005 | 04:15 AM
toEknEEg's Avatar
Default rebuild didnt start - weird stuff
NEW PROBLEM!!!
ok, turns out the timing was off becase the timing belt kept sliping off the intake cam... fixed.
now im having electrical problems... i got spark, i got fuel, and i got compression. almost every other time i put the key in, the CEL comes on. and it will flicker, then become dim as hell. so i change the battery, now something clicks under the dash when it cranks. CEL dimmes in and out.
some suggested a short, or an arc between something. bad grounds??
i got on on the valve cover, the tranny to the body, and the battery ground... am i missing one? i took out the fuse box during the swap, is there a ground behind that or something?
its been months since i drove this car, i miss it.... help me out honda-tech
ok i rebuilt my jdm ITR with new bearings, new piston rings, put in some cams, springs retainers, etc. im sure i got my timing right but im gonna double check that later today....
anyways, it doesnt start. i checked my fuel and spark, good. i go to do a compression test, and the compression tester gauge reads zero... the weird part is, there is a "THUNK" or "'PHOONK" coming from the intake manifold. this noise repeats everytime the motor cranks over....
i took off the IM and i didnt see anything out of the ordinary... gonna double check my timing today.... anyone know wtf is going on?
im clueless....
Modified by toEknEEg at 8:29 PM 10/17/2005
Old Oct 4, 2005 | 06:44 AM
green_GSR's Avatar
Default Re: rebuild didnt start - weird stuff (toEknEEg)
The compression pressure gauge shouldn't read zero. Even with a fresh motor, it should never read zero. Double check if the gauge is in working order.
When you mentioned a "Thunk/Phoonk" sound, did you hook up your firing order correctly?
Old Oct 4, 2005 | 12:07 PM
Sam92Teg's Avatar
Default Re: rebuild didnt start - weird stuff (green_GSR)
Sounds like your crank and cams are out of phase.
Old Oct 4, 2005 | 12:58 PM
civicguy's Avatar
Default Re: rebuild didnt start - weird stuff (Sam92Teg)
believe me do a valve adjustment and she will start right away,thats is you had put a more agressive cam
Old Oct 4, 2005 | 01:10 PM
Surubasi00's Avatar
Default Re: rebuild didnt start - weird stuff (civicguy)
make sure your spark plug wires are wired correctly....
i had mine 180 off (1 was on 4, 2 on 3 etc. etc.) and it wouldnt fire, confused the **** out of me for about three days!
Dave
Old Oct 4, 2005 | 01:59 PM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy &raquo;</TD></TR><TR><TD CLASS="quote">believe me do a valve adjustment and she will start right away,thats is you had put a more agressive cam</TD></TR></TABLE>
same thing happened when i got my fresh head back from JG. I bolted it on and scratched my head for days cuz it wouldnt start! Comp test = 0 compression in all 4, so valve adjustment and it was back up to 170(sohc). But my coil was also shot so that made it take even longer.
Old Oct 4, 2005 | 02:07 PM
DonF's Avatar
Default Re: rebuild didnt start - weird stuff (kabaroo)
Check cam marks at TDC, adj. valves. Engine stuff 101.
Old Oct 17, 2005 | 04:29 PM
toEknEEg's Avatar
new problems!
Old Oct 19, 2005 | 03:27 PM
toEknEEg's Avatar
help me out...
Old Oct 19, 2005 | 03:33 PM
92TypeR's Avatar
FSAE
Basic steps.
*Check crank at TDC
*Check cam sprokets at TDC
*Rotate the crank counterclockwise 2 revolutions, cam sprokets should maintain their TDC aligment.
*Check that you have the wireing correct. Are the TPS and MAP clips on the correct sensor? (same clips, read differently).
*Check fuses, relays. If you removed the fusebox, one of these may have become loose, or broke.
Do you have a fuel pressure gauge? If so, what is your pressure when you prime the car.
Check that the ECU you are using works.
Check that you are getting spark out of the sparkplug wires (arc them to a chassis bolt).
Start there, come back after you do those.
Old Oct 19, 2005 | 08:53 PM
black cx's Avatar
Default Re: rebuild didnt start - weird stuff (92TypeR)
good luck
Old Oct 19, 2005 | 10:18 PM
ATS*Mark's Avatar
OG triple OG
Default Re: rebuild didnt start - weird stuff (black cx)
cold time the motor....adjust the valves and check the firing order .then make sure you have fuel spark and compression. she will start right up trust me.
Old Oct 19, 2005 | 10:49 PM
killa_D's Avatar
^^^^ he right
Old Oct 23, 2005 | 10:09 AM
toEknEEg's Avatar
Default Re: rebuild didnt start - weird stuff (Hella_JDM)
i've got those three components but something is shorting or something near the dash.... i checked all three as well. motor is still in time.
Old Oct 23, 2005 | 10:49 AM
ATS*Mark's Avatar
OG triple OG
valve job
Old Oct 23, 2005 | 05:13 PM
efcivic757's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg &raquo;</TD></TR><TR><TD CLASS="quote">NEW PROBLEM!!!
Check you thermostat ground. Sounds like the same problem I had when i did my b16 swap.
Spoon_EJ
Oct 13, 2016 05:18 PM
Lennon
Nov 14, 2012 06:50 PM
jonnybadboi9
Jul 16, 2009 10:25 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
CRX91SE
Aug 28, 2007 03:40 PM
