My 2nd Drop Didnt go so WELL...
So i had my del sol dropped 2.25" on springs before, now i dropped it at the same height but with D2 coilovers and skunk2 camber kits. Before (w/springs) i noticed a slight camber. Now that i fixed the camber, the front wheels are toed out! what do i do? IF i take it to get aligned will they fix that?
have alignment done... if it's too much to drive the car like that, jack the car up, unscrew the tie rod bolt and rotate the tie rod till the tire looks to point straight... do the same for both sides... then go take it to a shop to have it aligned correctly
