skunk2 lowering springs
Hi,
I searched the forum and I'm getting mixed results as to whether I'm going to need to buy camber kits.
I know I'll need an alignment (I need one anyway), but will the camber wear my (directional tread) tires unevenly?
Tires are expensive.
I don't mind buying them if they put the camber at stock, but what experience have people had dropping and with camber? Also; is there a cheaper way to adjust camber?
Re: skunk2 lowering springs
Ok i've had a set of them before with and without a camber kit. Here's the thing it all depends on how much you lower it. If you are doing a big drop than you've got to have one to save your tires. Easiest way to see if you need one is to put those springs on than then take it to an alignment shop and see if they tell you the camber is way out.
Also it says you WILL have negative camber on the front..
...read it again.
plenty of those people if not all of them have drops.
i have a 1.8 drop with no camber kits after 2.5 years only needed to replace tires once in the front because i aligned it poorly.
blackccoupe
10
01-10-2009 07:54 PM
