Motor Mounts
Old Oct 3, 2005 | 07:21 PM
DriftTheEg's Avatar
Default Motor Mounts
Is it hard to change out the motor mounts for a 92 hatchback. My engine jumps when i go from park to neutral, and neutral to reverse, etc.
Old Oct 3, 2005 | 07:22 PM
BigPlansNoMoney's Avatar
Default Re: Motor Mounts (DriftTheEg)
You got a lift?
DriftTheEg's Avatar
Default Re: Motor Mounts (Justin_Bradley)
i have access to one
Old Oct 3, 2005 | 07:24 PM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriftTheEg &raquo;</TD></TR><TR><TD CLASS="quote">i have access to one
Then, no, it shouldn't be too hard.
Old Oct 3, 2005 | 07:27 PM
coquitlamEG's Avatar
just do them one at a time and you'll have no problem. Just place a jack or something under your engine to raise it just slightly so the weight is taken off the mounts.
Old Oct 3, 2005 | 07:28 PM
red02s2k's Avatar
Default Re: Motor Mounts (Screwtape.)
hey bro when i put my new mounts in it only took me a couple of hours just make sure you have something to pry with or something in that nature a friend always helps
Old Oct 3, 2005 | 07:33 PM
DriftTheEg's Avatar
Doesnt sound too hard. Do you guys know how much they normaly run?
Old Oct 3, 2005 | 07:38 PM
Default Re: (DriftTheEg)
You lookin for upgraded or OEM replacements?
Old Oct 3, 2005 | 07:42 PM
DriftTheEg's Avatar
Default Re: (Justin_Bradley)
nothining in paticular. i had my car up on an alignment lift, and noticed when i shifted gears the whole engine would jump a little. i was told they needed to be replaced
Old Oct 3, 2005 | 08:04 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriftTheEg &raquo;</TD></TR><TR><TD CLASS="quote">nothining in paticular. i had my car up on an alignment lift, and noticed when i shifted gears the whole engine would jump a little. i was told they needed to be replaced</TD></TR></TABLE>Get some Energy inserts, should help.
Old Oct 3, 2005 | 08:24 PM
DriftTheEg's Avatar
Default Re: (HondaFanatic708)
What are those?
Old Oct 3, 2005 | 08:28 PM
Polyurethene inserts that slip over the rubber sections on stock mounts.
http://www.energysuspensionparts.com
Old Oct 3, 2005 | 08:44 PM
civic_driver's Avatar
Desiree and Lundsey, lmao...
umm yeah, or you could use windo-weld urethane to fill up the ones you have right now... i did it to the front lower ones.. i might get to do it to the rest in spring time
Old Oct 3, 2005 | 11:34 PM
built562's Avatar
Default Re: (civic_driver)
i wouldnt recomended too stiff of a motor mount because it does cause excess vibration in the car, i had prothanes and my car would literally buzz like a bee at exactly 3500rpm. if its your daily driver just get some oem mounts and change them one at a time.
you just need basic tools and a jack with some boards to jack up the motor
Old Oct 4, 2005 | 05:22 AM
dpkelly's Avatar
Default Re: (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt recomended too stiff of a motor mount because it does cause excess vibration in the car, i had prothanes and my car would literally buzz like a bee at exactly 3500rpm. if its your daily driver just get some oem mounts and change them one at a time.
you just need basic tools and a jack with some boards to jack up the motor</TD></TR></TABLE>
Old Oct 4, 2005 | 05:27 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (dpkelly)
Before you change your motor mounts, I'd do a fluid flush of your transmission. Auto trannys shift hard/harsh and jerk the car when the fluid is old/bad. I had to do this a few times on my old car. Fixed the problem right up.
Do your motor mounts have visible wear and tear on them?
Old Oct 4, 2005 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">Desiree and Lundsey, lmao...
</TD></TR></TABLE>Hondas are people too, right? ROFL.
Old Oct 4, 2005 | 09:19 AM
dpkelly's Avatar
Default Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Before you change your motor mounts, I'd do a fluid flush of your transmission. Auto trannys shift hard/harsh and jerk the car when the fluid is old/bad. I had to do this a few times on my old car. Fixed the problem right up.
Do your motor mounts have visible wear and tear on them?</TD></TR></TABLE>
I agree too. Honda is not known for the best auto transmissions. It takes at least 3 changes since alot of fluid is held up in the torque converter. By changing it several times, you're simply diluting the old fluid with new fluid. But Honda ATF only.
Old Oct 4, 2005 | 11:07 AM
JDM-EJ1's Avatar
It's an easy process. Just make sure you support the side of the engine/tranny when you're removing the corressponding mount.
Old Oct 7, 2005 | 07:39 PM
DriftTheEg's Avatar
I had a local shop i know pretty well take a look at my transmission. and even they suggested to change out my motor mounts. the trans. fluid was fine
EduardoDC5
16
Jan 8, 2009 10:52 AM
Streetballer4888
Honda Civic (2001 - 2005)
Apr 26, 2007 01:34 PM
Dumped DB2
Aug 2, 2005 11:00 AM
katzenjammer84
Welding / Fabrication
11
Nov 1, 2004 09:41 AM
Death_to_Thieves
Oct 28, 2004 04:42 PM
