Oil Pressure Gauge question (easy one, and its different too)
Ok, I tried a search and nobody seemed to question this.
Why can't I "splice" into the stock civic/integra oil pressure sender to get a signal for the gauge? I'm sure there has to be a reason for it.
Also can't I just replace the stock one w/ the aftermarket one and run the aftermarket gauge and also the stock light?
Or, finally - can I do as above (use aftermarket sender), and just use it for the gauge, not the light? Will it throw a CEL or sumthin?
Thanks, l8r
Thanks, l8r
The unit you see on the back of the block, if I am right, is not a unit that reads pressure. It reads that the pressure is above a certain level, but other than that does not return any readings. More of a dumby swithc than anything...
Jason
Jason
Jason
Jason
the oil pressure sending unit on MOST cars only sends a voltage if the oil pressure drops to 0 psi... or close to it. most electrical gauges will come with the sending unit.
Jason
The stock unit is an oil pressure switch, when the pressure drops below 5 psi or 3 psi ... it turns the oil light on...
you need to hook up an oil presure sending unit to be able to get oil pressure reading or a mechanical guage
