does anyone store there cars for the winter?? i need info..
im planning on storing my car and i was wondering what i should do to get it ready for its winter nap? i was planning to do a oil change just before storing it but i was wondering if i should do anything else..
Do something about the battery - either remove it (or put a disconnect switch on it) or, better yet, attach an automatic charger (the kind that stops charging when it's fully charged). Other than that, nothing is really essential.
I just start her up every sunday and run it for 30 min. Rev her up few time once
water temp reach normal operating level. I throw on battery charger once
amperage runs low by end of winter.
Remove the battery or do what Ken mentioned above and get a can of stabil for the fuel system. Maybe get a cover even if it's indoors. Other than that I usually just change fluids after I take it out of storage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go »</TD></TR><TR><TD CLASS="quote">I just start her up every sunday and run it for 30 min. Rev her up few time once
From what I read the above will actually hurt your car. Change oil, fill up the gas tank, add in some fuel stabilizer, disconnect the battery and put a trickle charger on it if you can. Some websites say remove spark plugs and add a little oil inside the cylinders and reinstall plugs. When ready to start, change oil, connect battery and start it right up.
djSALIX
Oct 8, 2005 05:23 AM
stock_civic
19
Nov 26, 2003 10:30 AM
