d16z6 turbo ?
Old Oct 3, 2005 | 04:04 PM
delsoldrew's Avatar
Default d16z6 turbo ?
i just got my block back from the machine shop and was wondering how much boost will the bottom end handle? i have suzuki vitara pistons on ls rods(yes i know getto fab style) and i also plan on getting a block gaurd. anyone recomend a block gaurd or are they all the same? thanx for the help!!!
Old Oct 3, 2005 | 05:14 PM
delsoldrew's Avatar
Default Re: d16z6 turbo ? (delsoldrew)
someones gotta know how much a stock z6 bootom end can handle with a block gaurd...HELP
Old Oct 3, 2005 | 05:49 PM
PRDM's Avatar
It not how much boost the setup will handle, but how much power it can handle (WHP). And it is not how much the block can handle but how much the rods would handle...
I would go with whatever stock LS rods can handle. Whats the breaking point of those rods, like 250-300whp im not sure but just search it...
Old Oct 3, 2005 | 05:50 PM
PRDM's Avatar
Default Re: d16z6 turbo ? (PRDM)
Why didnt you go with eagle, or turbo toys H beams?
Old Oct 3, 2005 | 05:57 PM
underb00steg6's Avatar
i think your stock bottom end can take 10psi with good tuning ofcourse ..anymore than that i would say is pushing it even with a block guard. ....
Old Oct 3, 2005 | 06:06 PM
PRDM's Avatar
Default Re: d16z6 turbo ? (underb00steg6)
A T3 super 60 @ 10psi is going to give you alot more power then a T28 @ 10psi... So due to the fact that we dont know what turbo or setup he is putting in his car you have to refer to how much power can it hold NOT psi...
Old Oct 4, 2005 | 03:26 AM
delsoldrew's Avatar
im goin to be using a t3 with a 60 trim. i used ls rods cause they were free and the shop only charged me 15 bucks a rod to fit them to the crank. i was told they can handle 250 to the wheels safely.so my thought of a 15 pound boost tune is kinda pushing it huh? thanx for the imput above fellas!!!
Old Oct 5, 2005 | 06:14 PM
delsoldrew's Avatar
anyone boost a z6??? how much boost did you run???
Old Oct 5, 2005 | 06:43 PM
Street Ghost's Avatar
to give u an idea.. i'm pushing 7psi with a T3 Super 60 on my D16z6 and its making 200whp/164wtq (tuned & intercooled).
Old Oct 5, 2005 | 07:20 PM
Hybrid96EK's Avatar
Default Re: d16z6 turbo ? (Street Ghost)
That block should be sitting in the machine shop AFTER you install the block gaurd, not before.
Old Oct 6, 2005 | 12:42 PM
delsoldrew's Avatar
Default Re: d16z6 turbo ? (Hybrid93Eg)
my buddy and i pressed one in a b18 bottom end with a hammer and 2x4 piece of wood and worked fine??? are d16s different???
Old Oct 6, 2005 | 01:57 PM
EJ1 wilcox's Avatar
I think the LS rods are good to about 300whp or so... and I think that would be the limiting factor in your case.
The vitaras should be fine to that much, and the sleeves shouldn't have a problem either, with a good tune that is.
I think you will have to spin that 60 trim T3 up to 15-20psi of boost in order to make that much power, and I don't think the turbo is efficient at that range. I'd have to recheck the compressor map though.
Old Oct 6, 2005 | 02:46 PM
delsoldrew's Avatar
Default Re: d16z6 turbo ? (EJ1 wilcox)
im hoping to get around 250whp at 17psi anyone think ill be alright with that? im plannig on getting AEM_EMS for the tunning...
coments on if possible or not...
thanx
Old Oct 6, 2005 | 03:16 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsoldrew &raquo;</TD></TR><TR><TD CLASS="quote">im hoping to get around 250whp at 17psi anyone think ill be alright with that? im plannig on getting AEM_EMS for the tunning...
thanx</TD></TR></TABLE>
Sounds about right to me. You shouldn't have any problems hitting 250whp with 17psi on that turbo/engine combo.
That's going to be a blast to drive! I had that turbo on my d16z6 at 12psi and it kicked ***
Old Oct 9, 2005 | 03:54 PM
delsoldrew's Avatar
anyone else boost a z6???
Old Oct 9, 2005 | 03:58 PM
coquitlamEG's Avatar
check this site out. They can tell you anything you want to know about boosting a d series.
http://www.turbod16.com
Old Oct 9, 2005 | 08:12 PM
chrisgags13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsoldrew &raquo;</TD></TR><TR><TD CLASS="quote">someones gotta know how much a stock z6 bootom end can handle with a block gaurd...HELP</TD></TR></TABLE>
none..they never work....better switch back to na for supreme gas savings
Old Oct 9, 2005 | 08:38 PM
Hybrid96EK's Avatar
Default Re: d16z6 turbo ? (chrisgags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgags13 &raquo;</TD></TR><TR><TD CLASS="quote">
none..they never work....better switch back to na for supreme gas savings</TD></TR></TABLE>
WTF?
Old Oct 10, 2005 | 11:08 AM
cartunescivic's Avatar
yes sir i have a 2000 civic coupe with a d16y8 bottom end and a z6 head, daily driven @10psi with no problems, it is also tuned and intercooled
Old Oct 10, 2005 | 11:09 AM
oh yeah and it made 220whp with 210lbs at 5000rpm with the clutch slipping, and gets 31mpg lol
thugsbryan
Mar 27, 2015 09:48 AM
GT500FTW
May 16, 2013 10:27 AM
beginmyhonda
Aug 5, 2011 08:13 AM
mugencivic94
Dec 29, 2005 08:12 AM
LoSt is BlaCk
Aug 12, 2003 10:39 AM
