distributor install help
Old Oct 3, 2005 | 10:22 AM
redwinqs's Avatar
Default distributor install help
So dizzy crapped out on me and now Im attempting to install my new one, thing is the camshaft moved so its now like (/) instead of (|) so the holes dont line up on the distributor correctly. whats the easiest way to adjust the camshaft to get it to line up correctly?
any help is appreciated.
Old Oct 3, 2005 | 10:27 AM
egryda's Avatar
Default Re: distributor install help (redwinqs)
crank your engine over a little bit.
Old Oct 3, 2005 | 10:47 AM
redwinqs's Avatar
Default Re: distributor install help (egryda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egryda &raquo;</TD></TR><TR><TD CLASS="quote">crank your engine over a little bit.</TD></TR></TABLE>
so jus act like im gonna start it up?
Old Oct 3, 2005 | 10:51 AM
Doeboy's Avatar
take a 19mm and turn the crank over a little, trying to start it will prolly move the cam to much. just do it manually. its way easier
Old Oct 3, 2005 | 10:52 AM
Luserkid's Avatar
uhh... you do know that the dist. can move right? Why not just rotate the fins?
Old Oct 3, 2005 | 10:55 AM
redwinqs's Avatar
Default Re: distributor install help (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEh2 &raquo;</TD></TR><TR><TD CLASS="quote">take a 19mm and turn the crank over a little, trying to start it will prolly move the cam to much. just do it manually. its way easier</TD></TR></TABLE>
wheres the bolt at to turn it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">uhh... you do know that the dist. can move right? Why not just rotate the fins? </TD></TR></TABLE>
adjustable holes barely line up to screw the 3 bolts back in...i can get the dizzy to more right but that doesnt help, needs very little to the left.
Old Oct 3, 2005 | 10:57 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redwinqs &raquo;</TD></TR><TR><TD CLASS="quote">adjustable holes barely line up to screw the 3 bolts back in...i can get the dizzy to more right but that doesnt help, needs very little to the left.</TD></TR></TABLE>
huh? The fins on the distributor turn 360. I still dont see why you cant turn the fin to / and put it in with the holes lined up. If you cant spin the fins 360 then somethings wrong with that dist. from the start.
Old Oct 3, 2005 | 11:00 AM
redwinqs's Avatar
because with the camshaft like this / it is making the dist. fit too far the right right...need to shift it left by adjusting the camshaft to |
Old Oct 3, 2005 | 11:03 AM
Luserkid's Avatar
lol.... i dont see how your thinking this is that hard. You set your dist. like this / put it in then move the dist. to line up the holes. The dist. will move because the cam is holding the fins.
Old Oct 3, 2005 | 01:19 PM
redwinqs's Avatar
well i got it on...and still doesnt start up...ehh gotta check fuses and then onto the starter...
Old Oct 3, 2005 | 09:43 PM
Luserkid's Avatar
Is the fuel pump priming?
WhiteOnRice
20
Jan 5, 2009 07:50 AM
vxnine
Jul 25, 2005 03:20 PM
Creepin4DR
Mar 6, 2005 02:11 PM
mrbig
Feb 10, 2005 10:05 AM
bad-monkey
Dec 5, 2004 05:22 AM
