Hit a Pothole... need help
Old Oct 3, 2005 | 09:50 AM
JoHA's Avatar
Default Hit a Pothole... need help
The Story
6:30 this morning i was driving from home to school, and came around a big turn. Some douche was half way in my lane so i drove over the white fog strip and just as i glanced down. BOOM. Big *** pothole engulfed my front passenger side wheel.
The Problem
Obviously you can expect the wheel to be somewhat damaged. And it is slightly bent. But the thing that gets me is when i turn to the right, 90 degree turns or more, the car clicks in the back passenger side of the car.
I appreciate any ideas that you throw at me. Im deffinately going back there on my way back home and taking pictures of the monster hole, and getting money from the state. F Michigan roads
Old Oct 3, 2005 | 09:53 AM
All-Out Motorsports's Avatar
clicking usually is the outer axle cv joint but if its coming from the rear...? i have no clue sorry
Old Oct 3, 2005 | 10:08 AM
92ehatch's Avatar
Default Re: (All-Out Motorsports)
i have hit a pothole the same way with my car, i dont know if i have a bent wheel or what, my whole steering wheel shakes tho.
is all you get is a click? if so it definately sounds like cv. maybe its ur ears playing tricks on u thinking it is the rear?
good luck with that
Old Oct 3, 2005 | 10:19 AM
Jorsher's Avatar
Yeah I think it's probably your ears playing tricks. If you hit with your front passenger side wheel it would most likely be that wheel that's damaged
Check the CV joint like the others said. That's usually what causes clicking.
Old Oct 3, 2005 | 10:46 AM
JoHA's Avatar
The CV was the first thing i thought... must be my retarded ears
Old Oct 3, 2005 | 10:51 AM
Baz007's Avatar
Noises that sound like they're form the back, tend to be from the front and visaversa
Old Oct 3, 2005 | 10:56 AM
Doeboy's Avatar
i would say your cv joint is the problem. check that **** YO
Old Oct 3, 2005 | 11:07 AM
.Ry's Avatar
.Ry
Default Re: (slowEh2)
Maybe the pothole clipped the axle and wala you have your noise.
Old Oct 3, 2005 | 11:41 AM
JoHA's Avatar
Ok... now if it does turn out to be... can i use the cv joint off of my friends 94 teg. My hatch has a b18c1 swap in it... im pretty sure it will work... hes wondering if it will work because his is an auto and mine is not.
Canadian_EF
Jan 21, 2010 05:29 PM
ryanstev
Suspension & Brakes
Nov 13, 2007 05:24 AM
ITRDC2R
Jun 1, 2007 05:43 AM
r3000
Dec 20, 2004 09:29 AM
zizux
Aug 28, 2003 01:11 PM
