whats the stock boost for this turbo
Old Oct 2, 2005 | 09:21 PM
Bartman201's Avatar
Default whats the stock boost for this turbo
i got a Garrett TB0356 from a saab 9000. it has a internal wastegate.
1.- I need to know how many psi is this wastegate set for?
2.- Whats the most HP i can make with this turbo?
thanks
Old Oct 2, 2005 | 09:38 PM
HiProfile's Avatar
Default Re: whats the stock boost for this turbo (Bartman201)
IIRC, most saabs are ~8psi, some 10psi.
I'd say only ~6hp on a honda motor...off of a weekwacker
Depends on the motor, but most b's & d's see around 9-13whp/psi gain over stock whp. I'm assuming it's a small 50 trim T3, so I'm gonna say 300hp maximum (flows 31lbs).
edit - the 'sponsored link' I see on my pc for that 'honda motor' is a 5.5hp gx160...
Old Oct 2, 2005 | 10:03 PM
Bartman201's Avatar
Default Re: whats the stock boost for this turbo (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">IIRC, most saabs are ~8psi, some 10psi.
edit - the 'sponsored link' I see on my pc for that 'honda motor' is a 5.5hp gx160... </TD></TR></TABLE>
sorry i forgot about my motor i got an 98 LS, low comp pistons, rods. port and pol head, block gard, valves, springs, retainers, fuel pump, fpr, chipped ecu, fmi and some more stuff that i can't recall
si90rex
Oct 22, 2009 06:08 PM
crxrider07
Sep 16, 2008 11:14 AM
BubbaPhu
Jan 1, 2007 02:05 PM
SlowSOHC-T
Jul 24, 2006 03:39 AM
tyrone27
May 22, 2004 10:58 PM
