Winter build, what should I do... suggestions...
Old Oct 2, 2005 | 07:11 PM
Topdawgg's Avatar
Default Winter build, what should I do... suggestions...
alright guys...
I have a b16 turbo setup that ive been runnin this year..
T304E tuned for 8psi and 370cc injectors...
Made 240whp and 167ft/lbs
I want to build a block this winter and im not sure what i should do.. MY options are:
B16 block
B17 Block with spun bearing..
b18a1 block
what block should i go with and what kind of build should I do... what will i need..what kind of price am I lookin at?
I wanna go for over 300whp...
I know im gonna need new injectors.. and im gonna look at 9.1-9.5 compression..
Any suggestions... let me have them...
Old Oct 2, 2005 | 07:46 PM
ccivic's Avatar
Default Re: Winter build, what should I do... suggestions... (Topdawgg)
B17 block with all new bearings. ~$300-400 for bearings (b17 for effect )
JE 9:1 forged pistons ~$400
eagle h-beam forged rods ~$300
sleeved (benson, or whatever sleeves you want) ~$1200
I'd go with 1000cc injectors ~$300, and Neptune ~$5-600 i think
As for the turbo kit..
Garrett GT35R
Neukin Ramhorn manifold
blowoff valve of choice
44m TiAL wastegate
and whatever bigass intercooler will fit under your bumper.
Old Oct 2, 2005 | 07:57 PM
Topdawgg's Avatar
Default Re: Winter build, what should I do... suggestions... (ccivic)
i already have the turbo setup... just lookin for the block build...
Old Oct 2, 2005 | 08:24 PM
Blackack26's Avatar
build the b18a bottom, and slap on your b16 head
Old Oct 2, 2005 | 08:25 PM
wantboost's Avatar
Who is Mr Robot?
b18 block, b16 head
Old Oct 3, 2005 | 10:45 AM
Topdawgg's Avatar
Default Re: Winter build, what should I do... suggestions... (wantboost)
ok, now what kind of a build should I do if i go with the b18a bottom end...
pistons
rods
sleeves?
Old Oct 3, 2005 | 10:53 AM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">ok, now what kind of a build should I do if i go with the b18a bottom end...
pistons
rods
sleeves?</TD></TR></TABLE>
Depends on your power goal really, people make upwards of 500whp on stock sleeves. Pistons and rods will take out the weak link in the bottom end, so you can rev high and make 500+.
Old Oct 3, 2005 | 07:16 PM
ccivic's Avatar
Default Re: Winter build, what should I do... suggestions... (Blackack26)
Don't risk pushing that much power with stock sleeves. If you're gonna go big, do it right. Sleeve the block, and get forged internals.. the end.
Old Oct 3, 2005 | 09:40 PM
Topdawgg's Avatar
what about block guard and run reasonable boost on it?
i have a t304E 67 trim... i dont think i can afford to upgrade the turbo this winter too..
should i even bother sleeving?
Old Oct 3, 2005 | 11:33 PM
1boostedcivic's Avatar
Default Re: (Topdawgg)
built ls vtec if u wanna make 200whp more. also look into some bigger injectors
Old Oct 3, 2005 | 11:54 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">what about block guard and run reasonable boost on it?
should i even bother sleeving?</TD></TR></TABLE>
sounds like an ssac turbo... although there is no such thing as a 67 trim
Old Oct 4, 2005 | 06:27 AM
Topdawgg's Avatar
Default Re: (wantboost)
yea... sorry... i read again.. it is the 57 trim
VTECdohcter
Jul 26, 2008 08:35 AM
lickety_britches
May 28, 2008 09:24 PM
lakai_19
Jan 13, 2007 08:07 PM
highbrid
May 7, 2003 12:33 AM
