Balljoint popped out? Why? How to fix it?
Old Oct 2, 2005 | 05:31 PM
Cuong-nutz's Avatar
Default Balljoint popped out? Why? How to fix it?
I was looking to see why my brake fluid was low the day after I filled it up and found out that my brake line to front right brakes was cut open. While I was inspecting around, I found that my balljoint had popped out. I went to the driver side to see it was the same and it wasn't--driver side was in all the way and flush unlike the passenger side. I think I also need to readjust my Progess camber kit. I think I have it on the wrong setting.
Why did it pop out? How do I put it back in?
Old Oct 2, 2005 | 06:14 PM
cambodia got civics too's Avatar
Default Re: Balljoint popped out? Why? How to fix it? (Cuong-nutz)
I guess the ball joint wasn't pressed on the control arm that good or maybe it was getting old, but just take it to a shop and let them press it on for you or buy a new control arm.
Old Oct 2, 2005 | 06:42 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (dnbCreative.COM)
yeah, not too bad. unbolt the knuckle, hit it with a hammer, then put in a new clip from the dealer. pretty simple.
Old Oct 3, 2005 | 11:06 AM
Cuong-nutz's Avatar
Default Re: (Redline96LX)
Damn, Checked both sides and both of them are missing the circlips. fawk! Just ordered the clips from Majestic Honda
Old Oct 3, 2005 | 11:08 AM
Ej1_coupe's Avatar
Default Re: (Cuong-nutz)
you don't really need to get the pins from the dealer, I saw them at sears hardware, so that might be your best bet.
marshun's Avatar
you can get that c clip at a home improvement store like home depot and stuff like that
Old Oct 3, 2005 | 01:34 PM
Cuong-nutz's Avatar
Default Re: (marshun)
I'll check it out
Old Oct 3, 2005 | 01:38 PM
Hebrew-Hammer's Avatar
I was gonna say hit it with a hammer but someone already covered that option
Old Oct 3, 2005 | 02:54 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
THere are no C-clips for the upper contol arm ball joints, they are simply pressed in. I say go to a junkyard and pick up a new control arm with ball joint, cuz it seems the that yours is loose now. I think a new aftermarket ball joint should cost around 20, I'm not sure how much OEM ones cost though.
Old Oct 3, 2005 | 03:07 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Balljoint popped out? Why? How to fix it? (rukawa1one)
I'd get a new ball joint because the old one has lost it's width from the constant running so even if you hit it back it will eventually come back up
Old Oct 3, 2005 | 03:37 PM
Cuong-nutz's Avatar
Default Re: Balljoint popped out? Why? How to fix it? (MugenHonda)
A new UCA or BJ does sound about right but then what is this part I ordered for:
Old Oct 3, 2005 | 04:24 PM
Sliced Beard's Avatar
that part that you ordered is the spring ring that holds the ball joint boot on to the UCA
Old Oct 3, 2005 | 04:47 PM
GBRacing's Avatar
Hum, it was my understanding that you could not simply replace the ball joint on the upper arm. That you had to replace the whole unit. Am I wrong?
Old Oct 3, 2005 | 04:48 PM
Default Re: (GBRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GBRacing &raquo;</TD></TR><TR><TD CLASS="quote">Hum, it was my understanding that you could not simply replace the ball joint on the upper arm. That you had to replace the whole unit. Am I wrong?</TD></TR></TABLE>
yes, you are wrong. They sell the ball joint seperately but it has to be pressed out and new one pressed in.
Old Oct 3, 2005 | 04:54 PM
Cuong-nutz's Avatar
Default Re: (DirtySol)
Damn. I hoped they didn't ship it out yet. Looks like I need a new UCA.
Old Oct 3, 2005 | 04:59 PM
Orangecivic251's Avatar
**** it big deal just buy the omni power uca for liek a 100$
Eighty-Nyne
14
Jan 24, 2009 10:41 PM
matryx
Jul 25, 2008 09:14 PM
welldun
Apr 9, 2007 05:52 PM
DaChoZn1
May 15, 2005 07:57 PM
Frosty_spl
Oct 29, 2002 11:05 AM
