Would a 96-98 factory rear lip fit on a 99-00 coupe?
There's this guy selling a 96-98 factory rear lip and i was wondering if anybody knew if it would fit on a 99-00 coupe. Its made for a coupe but im not sure if the 96-98 rear bumpers are the same as the 99-00 rear bumpers. If not how much shorter or longer is it?
Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (jstyle_si)
i ordered a new bumper today and i was told that the 96-98 bumpers are different then the 99-00 not sure if the lip would work or not though
Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (ek4d00r)
so just a few of the clips and it should fit on good? a friend of mine told me that the 96-98 rear bumpers are smaller than the 99-00 is that true? if it is than that means i would have to extend the lip by cutting it right?
you should pm scrapinsi, he had the 96-98 lip on a 99-00 bumper. as I recall he mentioned he had to trim the lip to make it fit.
1 Post
99-00 have a "lip" on the bottom edge already. 96-98s dont have that.
I have seen the old lip on the newer bumper with some mods.
Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (eK9aT10pSi)
actually the 96-98 lip wont even come close to fitting the 99-00 rear bumper. the 96-98 bumper concaves in along the bottom whereas the 99-00 does not. you will need to add around 4-6 inches of abs plastic to makee it fit!
i have tried this as i have a 00 si and my little bro has a 96 coupe and i tried to get his to fit and i wasnt even close enough to where i would even try to modify it to fit
Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (EM1_R)
you can make anything fit with a little creativity. ScrapinSi made a 96-98 OEM rear lip fit on a 99-00 and it looked like it came that way from the factory.
BTW, I have a 96-98 OEM rear lip for sale
cilvia
01-11-2006 09:27 PM
JMD
03-17-2003 04:51 PM
tnbigdawg
03-12-2003 06:24 PM
