Block making noise like a ticking sound.. is it normal?
Old Oct 2, 2005 | 04:23 PM
VtecbOi's Avatar
Default Block making noise like a ticking sound.. is it normal?
it's still on the engine stand. i just got done putting in the rods and pistion. The head hasn't been install yet. its just that evertime one of the pistion hits top dead center you can hear a ticking sounds. if you put your ear right next to the piston as it hit top dead center you can here a tick coming right out of it. i mean it doesn't sound bad. and it does it on all 4 piston not just one. i never done a rebuilt b4 so i don't know if that is normal. I check everything. the crank rods are fine. nothing is hitting anything.. even the rods and pistons. i checked everything. and everything seem to be within spec. i bolt all the nut down to spec. so i don't know. maybe my rings are alittle to hard on my block. the crank and block was done at the shop. so there shouldn't be anything wrong with it. Please let me know... right now i'm just sitting thinking if i should put the head on and just go for it.
Old Oct 3, 2005 | 04:33 AM
VtecbOi's Avatar
Default Re: Block making noise like a ticking sound.. is it normal? (VtecbOi)
help anyone... help............
Old Oct 3, 2005 | 09:02 AM
THC07's Avatar
yeah, thats a fucked situation.
THC07's Avatar
Default Re: Block making noise like a ticking sound.. is it normal? (THC1107)
Might be right though!
Old Oct 3, 2005 | 12:52 PM
VtecbOi's Avatar
what do you mean dont' you guys know anything. or are they not suppose to make no noise at all....
Old Oct 3, 2005 | 01:20 PM
VtecbOi's Avatar
it does it all the time on every piston so i guess it's not really soemthing hitting something. cause if that was the k the faster you turn the crank the louder the noise would be. but it does. slow or fast its still the same.. i think something isn't tight... i'm not sure..
Old Oct 3, 2005 | 01:37 PM
Hebrew-Hammer's Avatar
Are the rings seated correctly? Are they the right ones? other than that im confuggled.
Old Oct 3, 2005 | 03:17 PM
VtecbOi's Avatar
Default Re: (Hebrew-Hammer)
it only sound when it hits top dead center. doesn't like like a ding... the rings oh yea it is.. damn tight as hell. everything was done at the shop. i mean does it suppose to or it shouldn't sound anything... did you hear your piston makes noise.
Old Oct 3, 2005 | 06:29 PM
VtecbOi's Avatar
Default Re: (VtecbOi)
anyone else....
Old Oct 3, 2005 | 06:30 PM
im thinking since the rings are so tight that when the piston hits TDC and starts to go down the rings are moving and causing a tick sound.
Old Oct 3, 2005 | 06:34 PM
if all else fails wait till you get the head and do a compression test on all 4 pistons if that checks out then it will be fine.
Old Oct 3, 2005 | 08:10 PM
VtecbOi's Avatar
dude i hope that right. cause from the look of here man it is really tight check it out at
http://members0.asianavenue.com/FirsTime
Old Oct 4, 2005 | 12:47 PM
hmm they look normal, like i siad run the compression test once its all together. also it could be clicking due to no lubrication.
Old Oct 4, 2005 | 12:57 PM
JDM-EJ1's Avatar
Damn. I've never heard of anything like this. This is crazy!
tallblondkid
Jul 9, 2017 04:26 PM
1badteg
Apr 10, 2008 11:52 AM
slowassciv33
Sep 12, 2006 12:25 PM
W O T
Jun 7, 2005 09:18 AM
