just swapped zc in hatch...idles at 2000rpms???
Old Oct 2, 2005 | 01:15 PM
bdiddy0036's Avatar
Default just swapped zc in hatch...idles at 2000rpms???
i just sawpped a sohc zc into my 91 dx. it idles really high...2000rpms. i think it might be because i am using an obd0 90-91 integra LS ecu. i was thinking it might be because the integra ecu has richer fuel curves. can someone help? maybe it might be something else?
Old Oct 2, 2005 | 01:18 PM
kulangot's Avatar
Default Re: just swapped zc in hatch...idles at 2000rpms??? (bdiddy0036)
did you adjust the screw on the throttle body?
Old Oct 2, 2005 | 01:23 PM
SomeDude56's Avatar
throwin codes? is it idleing like that after its warmed up?
Old Oct 2, 2005 | 01:28 PM
bdiddy0036's Avatar
Default Re: just swapped zc in hatch...idles at 2000rpms??? (kulangot)
no i didnt ajust the screw?
Old Oct 2, 2005 | 01:29 PM
bdiddy0036's Avatar
Default Re: just swapped zc in hatch...idles at 2000rpms??? (SomeDude56)
no its not throwing any codes at all. and it idles at 2 when its warm too
Old Oct 2, 2005 | 01:37 PM
kulangot's Avatar
try ajusting the screw..
onepoint6i's Avatar
you have a vaccum leak somewhere..did you use the right TB gasket? Is it the original TB?
Old Oct 2, 2005 | 01:40 PM
bdiddy0036's Avatar
Default Re: just swapped zc in hatch...idles at 2000rpms??? (onepoint6i)
original TB
Old Oct 2, 2005 | 01:42 PM
bdiddy0036's Avatar
do you really think its a vaccum leak, cuz i was worried i didnt get all the vaccums right? would that make it idle at 2000rpms. it runs really smooth.
Old Oct 2, 2005 | 01:55 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdiddy0036 &raquo;</TD></TR><TR><TD CLASS="quote">do you really think its a vaccum leak, cuz i was worried i didnt get all the vaccums right? would that make it idle at 2000rpms. it runs really smooth.</TD></TR></TABLE>
lol, what else is it gonna be...
when a engine idles higher than normal, it is getting air from somewhere its not suppose to..
either that or your iac isnt doin its job, but you would be getting a code for it..
Did you do the dual point-pgmfi conversion or are you using the DX manifold?
Old Oct 2, 2005 | 02:02 PM
bdiddy0036's Avatar
yeah i did the conversation to multi-point
bryan469
13
Mar 20, 2013 06:36 AM
Ek4drcindy
10
May 18, 2011 04:13 PM
CRXguy_88
Sep 23, 2010 06:11 AM
dubstackz
Dec 3, 2007 09:55 PM
beatthisspeed69
May 16, 2006 09:54 AM
