Boost D16 or ZC?
Old Oct 2, 2005 | 11:30 AM
91crxracer's Avatar
Default Boost D16 or ZC?
i currently have a ZC in my 91 crx and i need some info and opinions on what most ppl would rather have a boosted ZC or a d16y8? i have heard from many different sources that zc's are junk and to go wit the d16y8... but i dont know? so what do you think? is the ZC worth a damn to build or should i build the y8? im looking for about 250-300hp. thanx
Old Oct 2, 2005 | 12:26 PM
IGotNoSwap's Avatar
Default Re: Boost D16 or ZC? (91crxracer)
250-300 will be pretty much fully built on either motor. id say go with the y8 and boost that. i got a friend with a y8 pushing around 300- 350whp on 8lbs of boost.
Old Oct 2, 2005 | 03:33 PM
HiProfile's Avatar
I'd recommend the y8 due to it being newer and being easier to convert to obd1. It's also easier to get to that power level by adding a zex cam. It's also easier to get parts for. Conversely, the ZC would be easier to tune since it's just a single boost map you need. A ZC will be easier to find with lower miles, but you can find y8's with low milage too. Previous threads have shown that stock motors aren't reliable after 200whp w/o proper tuning.
Personally, I'd go with a Z6 head and a y7 or y8 block and a zex cam - since I already all 3.
Old Oct 2, 2005 | 03:51 PM
cmyrex's Avatar
Do the sohc the ZC is the bastard engine when it comes to part. Do the built sohc and i am pretty sure with some effort and some good cash flow you can get those numbers
Old Oct 2, 2005 | 04:14 PM
theemaddhatterr's Avatar
i'd go with the dohc zc but i don't like the y8 they aren't as reliable have a problem with spinnig bearings
89CRXProject
Mar 21, 2009 02:29 AM
sohc'd upEJ8
Apr 3, 2006 08:38 AM
92CHB
Oct 5, 2005 07:01 AM
USDMMARK
Sep 7, 2003 10:13 AM
