Milling CTR pistons......
Old Mar 3, 2002 | 01:27 PM
One Bad GeeSeeR's Avatar
Default Milling CTR pistons......
is it okay to mill the ctr pistons instead of si rods? the reason i was thinking this cuz if i have to go back to stock i wouldnt have a problem. now also will milling the pistons weaken the pistons? any help please.....
carlo
Old Mar 3, 2002 | 04:08 PM
sohc_boy's Avatar
Default Re: Milling CTR pistons...... (ChampwhiteSi)
mill pistons? y? ctr pistons will fit the si rods u just have to have the piston pins done by a machine shop (they r pressed in).
Old Mar 3, 2002 | 06:26 PM
FSTASNTZ's Avatar
Seeing how the rod is a stronger and thicker material, I would suggest milling the rod, and not the piston. Not sure if it will change any of the properties of the piston pin journal, such as tolerances...
Jason
Old Mar 3, 2002 | 09:05 PM
Halo's Avatar
Default Re: Milling CTR pistons...... (FSTASNTZ)
ctr's are cast and not billet aluminum, so there is less material to deal with in casts
[Modified by Halo, 10:06 PM 3/3/2002]
Old Mar 4, 2002 | 04:53 AM
sohc_boy's Avatar
Default Re: Milling CTR pistons...... (Halo)
y would u mill a rod? maybe balance, or resize but not mill.
Old Mar 4, 2002 | 08:34 AM
VTEC4GS's Avatar
cut material off the piston not the rod ...
Greg
Old Mar 4, 2002 | 10:23 AM
Katman's Avatar
yes it's ok to take material off the inside of the CTR piston's wrist pin area rather than the B16A rod. I've seen this done before. It's suggest to get the pistons balanced after they've had this modification done to them.
wmertz187
13
Feb 5, 2007 09:41 PM
nissanjon
Dec 1, 2004 05:50 PM
Dropspeed
Sep 4, 2004 05:15 AM
CrazyKoreanCrx
Feb 26, 2004 01:45 PM
djickabod
Oct 26, 2003 12:07 PM
