is my headlight bulb f-ing p?
Old Oct 2, 2005 | 09:17 AM
loup05's Avatar
Default is my headlight bulb f-ing p?
my headlight on the passenger side dosnt shione as much as my left one. at night i can barely see the reflectin on the gorund could it be that the last owner put in a diff bulb than the one on the left?
Old Oct 2, 2005 | 09:21 AM
HondaTechPro's Avatar
Default Re: is my headlight bulb f-ing p? (loup)
you should look at the lights when they are on. Is one dim compared to the other? Or are you jusy comparing what you see on the ground in front of you?
Old Oct 2, 2005 | 09:33 AM
P_Adams's Avatar
Well, if one side has a three year old oem bulb and the other side has a new Sylvania Silverstar, then yes I could see a difference in brightness. It sounds like you could (read that as "might") have a voltage issue to the dim side bulb.
You could also have a grossly out of adjustment condition where the "dim(er) bulb is pointed at the non-reflective asphault while the other points straight ahead.
If you've a volt/ohm meter, you can check for system voltage at the bulb with the lights turned on. If you have the correct voltage, turn the lights off and check for resistance between the socket ground terminal and ground (you should have none)
P
Old Oct 2, 2005 | 09:58 PM
loup05's Avatar
Default Re: is my headlight bulb f-ing p? (P_Adams)
one fo them is dimmer than the other 1. im thinking of just buying new sets of bulbs should i just buy any kind at p[ep boys or wut?
Old Oct 3, 2005 | 04:34 AM
P_Adams's Avatar
Probably the best bulb you can find in a store is the Sylvania Silverstars. You'll get great output at a reasonable price, PIAAs' (IMHO) are over rated, hidiously overpriced and basically all you're paying for is the name. Try to avoid the "HID Look" marketing on off-white hdlamp bulbs, you won't be happy with the results.
P
Old Oct 3, 2005 | 05:24 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup &raquo;</TD></TR><TR><TD CLASS="quote">my headlight on the passenger side dosnt shione as much as my left one. at night i can barely see the reflectin on the gorund could it be that the last owner put in a diff bulb than the one on the left?</TD></TR></TABLE>
Are they aimed properly?
Old Oct 3, 2005 | 05:55 AM
accordselux's Avatar
Me Gusta History
Default Re: is my headlight bulb f-ing p? (-Bionic-)
I've heard about this before, one side dimmer than the other. Switch bulbs and see if the problem persists. You may have the headlights misaligned, but I recall it was a grounding problem or something to do with wiring.
Old Oct 3, 2005 | 06:02 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: is my headlight bulb f-ing p? (accordselux)
Good idea. Switch bulbs and see if there is a difference.
Old Oct 3, 2005 | 08:03 PM
loup05's Avatar
iight i will i have some time right now I'll post up wat happened when i switched the bulbs
Old Oct 4, 2005 | 07:39 AM
hometheaterman's Avatar
Could be the bulbs or a wiring issue I would try changing the bulbs first. For bulbs Silverstars are supposed to be good. Farenheits I like about as much and they are a hell of a lot cheaper neither really have a blue color to them. I like Eurolite Crystals and Fusions for a slight blue tint although they arn't real blue themselves but they seem to have decent output and still look good.
I have tried quite a few sets of bulbs but really don't feel like typing about all of them right now.
Old Oct 5, 2005 | 06:43 AM
loup05's Avatar
Default Re: is my headlight bulb f-ing p? (hometheaterman)
im having a real hard time taking out the bulb on the passenger side. i managed 2 disconect the power 2 it but i cant take it out the book says turn it clock wise but i tried turning counter and clockwise and that **** wont budge
Old Oct 5, 2005 | 06:51 AM
Me Gusta History
yea passenger side's pretty tough. Just takes some fiddling though. I had the same problem. You COULD unscrew the screws that hold the bulbs in place, there's the slot the bulb slides into, and it's usually held in by a screw...if you unscrew one the bulb will come right out...
Old Oct 5, 2005 | 07:22 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup &raquo;</TD></TR><TR><TD CLASS="quote">im having a real hard time taking out the bulb on the passenger side. i managed 2 disconect the power 2 it but i cant take it out the book says turn it clock wise but i tried turning counter and clockwise and that **** wont budge </TD></TR></TABLE>
It will come out. Use some muscle.
Old Oct 5, 2005 | 07:53 AM
P_Adams's Avatar
Different series (Gens') Accords have different bulb retention schemes, I don't see where you mention what year your's is......
P
Old Oct 5, 2005 | 08:06 AM
loup05's Avatar
95 lx
Old Oct 5, 2005 | 08:18 AM
P_Adams's Avatar
The fifth 5th Gens have a retention ring (about 2 1/2 " in diameter) with three serated finger grips which lock the bulb into the fixture. It is these rings that require turning about a quarter turn countet-clockwise to release the bulb. It's much like a "align the tabs" sorta thing. Once the tab reliefs are aligned, the bulb comes straight out.
Reverse the proceedure to install.
And, yes, the right side is the more difficult.. what with the tank overflow and the aircleaner box in the way ^%$&
P
Old Oct 11, 2005 | 10:35 PM
loup05's Avatar
ok i switched the bulbs ( right 2 left left 2 right.) and it seams that my passenger light shines more that the driver side with either one of my bulbs. it apears to be pointing higher than the other side how can i fix this?
Old Oct 12, 2005 | 04:47 AM
P_Adams's Avatar
The Honda Headlamp capsules can be adjusted using no more that a Number two (2) Phillips head screwdriver. The top adjustment (of course the easier of the two) adjusts the aim left-to-right. It's the 'honkin big screwhead off to one side.
The bottom one is the *&^%( one, and it adjusts the aim up-and-down. Unfortunately it's the one u need. Unfortunate in that it's a bear trying to discribe.
It's located in the vicinity just in front of the rad overflow bottle (which, by the way should be removed to make access easier) on the bottom of the capsule and if you get a flashlight on it, it looks like nothing more than a little box-like structure with a little cheap geared wheel in it. The drill is: the screwdriver is inserted thru the top, the flutes of the screwdriver engage the wheel teeth, and you can turn the adjustment shaft either way to change your aim. Surprisingly, it works.
I used a long shank Snap-on phillips driver to reach it.
Don't be surprised you find one or both adjusted's siezed from corrosion/age.
P
civicpark81
Lighting
May 14, 2012 08:38 AM
phoenix_iii
Aug 8, 2008 11:54 AM
casmello
Nov 28, 2005 07:32 PM
