Lighting HID/Xenon kits, Retrofits and Associated Topics
Rightside headlight low...
Old Apr 23, 2012 | 06:23 AM
civicpark81's Avatar
Icon2 Rightside headlight low...
So I just took out the HID kit on my civic and put the stock headlight set up, but the right side is super dim. At first I thought it might be the contacts were on wrong and i had reversed the polarity, but it wasnt that. I switched bulbs from the left side but issue remains, highbeams are the same issue. Any idea whats causing this??
Old Apr 23, 2012 | 12:29 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Rightside headlight low...
Have you checked for a short? I just finished my motor swap and my drivers side is really dim for both low beam and high beam. I have a feeling it some how shorted against the turn signal wire because when my lights are on, the left turn indicator is lit up a bit and the front turn signal doesn't work when the lights are on.
Old Apr 23, 2012 | 03:12 PM
I haven't yet but I will. Thx.
Old Apr 24, 2012 | 07:19 AM
Googled the quest and I found a blog and they said try the ground. So I rigged a cable and connected to ground on bulb and BINGO. Just FYI in case it ever happens to any off you. Thx again for the tips and help.
Old May 14, 2012 | 08:38 AM
I was just coming to say it was the ground that fixed mine as well.
unclematt
Sep 1, 2016 09:39 AM
W95civicEXcoupe
Mar 5, 2015 02:51 PM
erikiksaz1
Apr 11, 2006 01:31 PM
loup05
Oct 12, 2005 04:47 AM
WANARUNM
Nov 30, 2004 06:39 PM
