while cruising, putting it in neutral and car dies
Old Oct 2, 2005 | 12:27 AM
LilCivic04's Avatar
Default while cruising, putting it in neutral and car dies
i don't know what the problem is and its getting really annoying. when i am cruising and i push in the clutch to let my car in neutral, the car dies. but sometimes it drops really low and you can see everything dim for a second and the car jumps right back up. i've search and came up with all kinds of ideas. i clean my iacv and still does not help the problem. i have a d16z6
Old Oct 2, 2005 | 12:28 AM
EL Vap133's Avatar
Default Re: while cruising, putting it in neutral and car dies (LilCivic04)
Do you have a CEL or any codes?
Old Oct 2, 2005 | 12:43 AM
LilCivic04's Avatar
Default Re: while cruising, putting it in neutral and car dies (EL Vap133)
no cels at all
Old Oct 2, 2005 | 12:44 AM
LilCivic04's Avatar
if i let off the gas and then push in the clutch it will most of the time act like it will die and jump back up but 25 percent of the time it will die. its really annoying when i get to a stop light.
Old Oct 2, 2005 | 04:48 AM
93CX's Avatar
I used to have this problem as well.. I messed with my idle screw a little bit and it helped, didnt even increase my idle all it did was prevent it from stalling out.
Old Oct 2, 2005 | 05:49 AM
TurboEM1's Avatar
do you havew a lightened flywheel? try raising the idle, the revs seem to be dropping to fast
Old Oct 2, 2005 | 07:33 AM
LilCivic04's Avatar
Default Re: while cruising, putting it in neutral and car dies (TurboEM1)
i am using a lightened fly wheel, an unorthodox racing flywheel. should i raise my idle with the adjuster screw?
popwars123
Mar 31, 2009 04:08 PM
jarven093
May 16, 2007 10:29 AM
jarven093
May 16, 2007 10:26 AM
JDM-EJ1
Oct 1, 2004 08:12 PM
NaVamous
Jan 23, 2003 11:22 AM
