WasteGate Elbow Falling Off Manifold =(
needs more filler . tehres penetration but no filler to strengthen the WG elbow. ive seen the actaul material crack but rarely a weld. unless at the collector.
i know whos manifold that is cuz i can identify the welds. but im sure he will fix it no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">needs more filler . tehres penetration but no filler to strengthen the WG elbow. ive seen the actaul material crack but rarely a weld. unless at the collector.
i know whos manifold that is cuz i can identify the welds. but im sure he will fix it no problem. </TD></TR></TABLE>
im probally just gonna get it fixed locally to save me time and money. It was a bitch to put on, and its gurantee gonna be a bitch to take off send out, and put back on.
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition »</TD></TR><TR><TD CLASS="quote">well what mani is it.</TD></TR></TABLE>
I think I know but not 100%.
.. (OP), why are you not stating who it is? just wondering..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy »</TD></TR><TR><TD CLASS="quote">
.. (OP), why are you not stating who it is? just wondering..</TD></TR></TABLE>
dont want to bad mouth anyone. plus i already talked to the maker and they said they are willing to fix it if i send it back so it will gurantee not happen again, but i may just get it fixed locally by a awesome welder and they are willing to cover the costs to fix it.
it was a bitch to put on, and its gonna be a bitch to take off, then put it back on when it gets fixed so no deals no sending it back.
Check the position of your wastegate in relation to other things. I had the same situation. My problem was that top port on the wastegate would hit my intercooler when running it hard.
It looks to me like its the opposite. There seems to be enough filler...just not enough penetration. If you look at the last pic you can see massive amounts of undercut. Get a compitant welder to fix it and you should be good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">Kinda OT, but why is your EGT probe in the w/g elbow?</TD></TR></TABLE>
yeah wtf.
yeah wtf.
because i only need egt readings under boost. I dont need egt readings when im cruising and when im cruising im not where near boost levels that i need to worry about.
plus if you tap it on running 3, its prone to melting and getting in your turbo and messing stuff up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">
yeah wtf.</TD></TR></TABLE>
answered it above this post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
why do you only need egt's under boost, egt maters when in vac. too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">
why do you only need egt's under boost, egt maters when in vac. too</TD></TR></TABLE>
uhhhh... because egt vac isnt as important as under boost. and like i said i dont want to melt the egt probe and get it sucked in my turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">SS = SuperShitty...... should have beefed up the weldz...</TD></TR></TABLE>
i dunno if you read it, but its NOT a SSauthchrome manifold..
