Fuel system parts re-assemble
Old Oct 1, 2005 | 05:07 PM
DjTrex's Avatar
Default Fuel system parts re-assemble
91 Accord EX (AT) I just cleaned my EGR ports and had to remove a part that i believe is part of the fuel system. SEE PIC [url=http://home.comcast.net/~cyberTNT/91Accord1d.jpg[/url][url=http://home.comcast.net/~cyberTNT/91Accord1f.jpg[/url]
Before i took this part off i cracked open the 17mm bolt on the top of the fuel filter to release the pressure. Then i removed the part pictured.
Now that i'm done and ready to put the parts back on. What order do i do it in? Does it matter what part i tighten first? The part in the picture or the 17mm bolt on the fuel filter? Do i need to be worried about getting air in the fuel lines from having these two parts off? If so, how to i purge the air from the lines?
thx, Wayne
Old Oct 2, 2005 | 07:23 AM
Chiovnidca's Avatar
Default Re: Fuel system parts re-assemble (DjTrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjTrex &raquo;</TD></TR><TR><TD CLASS="quote">
Now that i'm done and ready to put the parts back on. What order do i do it in? </TD></TR></TABLE>
Just put it back together reverse of the way you took it apart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjTrex &raquo;</TD></TR><TR><TD CLASS="quote"> Do i need to be worried about getting air in the fuel lines from having these two parts off? </TD></TR></TABLE>
No
vltnolia
Feb 14, 2007 11:24 AM
Da K00l Aid Mayun
Sep 6, 2005 10:30 AM
CivicHB89
Jan 4, 2005 05:18 PM
Joel_MN
Aug 17, 2003 11:59 AM
GODluvsLUDES
May 13, 2003 07:53 PM
