b18a vs b18b
Old Mar 3, 2002 | 10:53 AM
robbin's Avatar
Default b18a vs b18b
I have a 90 ls with a b18a with 130 hp. The later b18a's and b18b's produce more power and torque. Does anyone know what the difference between these #'s are. Is the cam profile, ecu programming, IM design, head design. I was just thinking that if it's something simple, like swapping the head, it'd be a good cheap mod for 12 hp. Also, if it's only cam profile then the crower 403's should give me like 30 hp if they're good for almost 20 in the b18b.
Old Mar 3, 2002 | 11:00 AM
Katman's Avatar
Default Re: b18a vs b18b (robbin)
you just answered your own question. B18B's, yes, have a better intake manifold design, better ecu programming, exhaust manifold design, and I believe a better cam profile.....all of these things combined make it have a bit more power than the B18A engines.
non-VTEC's Avatar
i think it's a combination of the cams/intake manifold and exhaust manifold which made up the diffrence between the two.
Old Mar 3, 2002 | 11:02 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: b18a vs b18b (non-VTEC)
better flowing head as well.
Old Mar 3, 2002 | 09:12 PM
Quick 200k Mile Motor's Avatar
Default Re: b18a vs b18b (B18C-EJ1)
Both Cylinder Heads flow the same.
It is the cam profiles introduced in 92' that made the 10 extra "rated" hp (increase from 130hp to 140hp).
In 94' the B18b's started, which had the same cam profiles as the B18a's in 92-93', but a better intake manifold which made the 2 hp increase in the rated hp (140hp to 142hp).
All cam profiles from 92' and up are the same (in all the 1.8 non-vtec's).
Old Mar 10, 2002 | 11:49 AM
EightOhOne's Avatar
Default Re: b18a vs b18b (Quick 200k Mile Motor)
So by swapping cams from a 92 or 93 into the 91, you can get the 10 extra hp? Is that possible?
Old Mar 10, 2002 | 12:20 PM
robbin's Avatar
Default Re: b18a vs b18b (EightOhOne)
So there's no difference in actual head design, it's just what bolts on to it (ie. IM, exhaust manifold, cams). So a b18a and b18b with skunk IM, crower 403's, and same header would produce the same flywheel hp? At least in theory? Well, that's good to hear.
Old Mar 10, 2002 | 10:44 PM
Default Re: b18a vs b18b (EightOhOne & Robbin)
Doing that, you get 5-8 untuned whp.
No need for aftermarket cams to produce whp equal to rated flywheel hp. A B18a, with 92 and up cams, i/h/e, FPR, Adj. Cam Gears, & Timing tuned on the dyno can get up near 140 whp with 20% more tq than B16a.
Old Mar 11, 2002 | 05:17 AM
X2BOARD's Avatar
I always thought it was a slight redesign of the quench area that increased this 2 hp....?
Old Mar 11, 2002 | 02:02 PM
robbin's Avatar
What I meant was that a b18b with all those bolt-ons would not have an advantage over a equally modded b18a.
Old Mar 11, 2002 | 03:39 PM
Default Re: b18a vs b18b (X2BOARD & Robbin)
quench combust area is the same. The heads are exactly the same, except for the Valve Cover.
I see. The difference in power gains would be close, except for whenever you get into the newer B18B's OBDII it produces less. *Transmission is also a factor. 94' and up hydro trannies have the longest gearing out of all the B-series trannies. Fastest setup would be an OBD-0 or OBD-I with the 90-93' Cable tranny. BTW, Tranny parts are interchangable.
Old Mar 14, 2002 | 07:16 PM
StorminMatt's Avatar
Don't forget the ECU. You can add better cams and a better intake manifold. But the ECU also needs to be tuned to take advantage of them. So if you add the later stuff to an earlier engine and keep the earlier ECU OR if you run a later motor with earlier electronics (as is often does to simplify wiring when doing, say, a 1994-1995 B18B swap into 1988-1991 Civics), you will not realize the full power gains.
As far as the head, I am still somewhat unclear on this. Alot of people have said that the 1994-1995 head is better. But it is still just a PR4 head. The B20Z, on the other hand, uses a P75 head, which indicates it is an updated head compared to the B18B head.
Jonathan_ED3
15
Jun 30, 2005 03:25 PM
quicksol95
May 17, 2005 03:30 PM
95lsteg
Dec 3, 2003 04:10 PM
haggar
Aug 15, 2003 04:04 PM
crxjake
Jun 16, 2003 02:14 AM
