Ball joint removal
Old Oct 1, 2005 | 11:56 AM
bryan073's Avatar
Default Ball joint removal
I have a 92 integra and I want to put on adjustable ball joints but I am can't find anywhere how to remove the stock ball joints. Are they pressed in? Do you need to have them pressed out? Any help would be appreciated.
Old Oct 1, 2005 | 12:56 PM
ricebucket's Avatar
Default Re: Ball joint removal (bryan073)
There is a ring clip that locks it in place....once that is off you can use a mallet to knock it out from the bottom up. Its not that difficult at all.
Old Oct 1, 2005 | 01:02 PM
bryan073's Avatar
Default Re: Ball joint removal (ricebucket)
Thanks for the info.
Old Oct 1, 2005 | 01:28 PM
bryan073's Avatar
Is it easier to take the upper arm off to do this or can it be done while still on the car?
Old Oct 1, 2005 | 02:24 PM
99_dc2's Avatar
I had a really hard time getting the ball joint to pop out of the uca and lca. I tried hammering the medal piece that the ball joint is connected to, but it wouldn't pop out. After so many hours of messing with it, I got fed up with working on that so I went to a local auto parts store and bought a pit man arm puller. After buying that, all the ball joints came off easily. You might want to consider buying that if all else doesn't work out.
This is a Pitman arm puller.
Old Oct 1, 2005 | 03:07 PM
projectTeG's Avatar
remove the snap ring thats under the boot on the upper arm and hit with a hammer a few times and it should pop right out. ive done this very same install.
Old Oct 1, 2005 | 06:50 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (projectTeG)
use that tool ^^^^ i rented one from Autozone to remove my front ones and it worked GREAT!
halocore
Mar 7, 2009 04:34 PM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
rasinhell
Feb 3, 2005 01:47 PM
ultraforce77
Jul 15, 2004 02:59 PM
97hb
Mar 9, 2002 11:31 PM
