11 to 1 compression LS CRX
Old Oct 1, 2005 | 11:40 AM
non-vtecpower's Avatar
Default 11 to 1 compression LS CRX
USDM ITR pistons on ls rods
port and polish
30 thousands shaved off of the head
Got about 2000 miles on it now runs strong,Need adjustable cam gears though.
Old Oct 1, 2005 | 12:00 PM
kulangot's Avatar
Default Re: 11 to 1 compression LS CRX (non-vtecpower)
so what is your ?..?
Old Oct 1, 2005 | 01:06 PM
TheBobFather's Avatar
Default Re: 11 to 1 compression LS CRX (kulangot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot &raquo;</TD></TR><TR><TD CLASS="quote">so what is your ?..?</TD></TR></TABLE>
Lol, yea
Old Oct 1, 2005 | 02:17 PM
I just got a digital camera wanted to post pics... I guess this is the wrong thread. umm so i guess my question is .. Has anybody had a similar setup if so what kind of HP numbers and 1\4 mile times
Old Oct 1, 2005 | 02:25 PM
kulangot's Avatar
Default Re: (non-vtecpower)
my friends old crx just had some regrind cams in his ls with s1 tranny and a act six puck clutch and he ran a 14.7 at 93mph....but you should take it to the track and let us no what you run..
Old Oct 1, 2005 | 02:26 PM
vbspec's Avatar
So you are keeping this car huh?
http://dragva.com/forums/showt...t=CRX
Old Oct 1, 2005 | 02:34 PM
Default Re: (vbspec)
As long as i still have it im going to keep putting money into it. But it is forsale.
Old Oct 1, 2005 | 03:20 PM
Im still OBD 0 and i had a pr4 in but it kept throwing a 02 code so i have this other obd 0 ecu it a PG7 what the hell is it for and sometimes with this ecu i have no rev limiter..runs good with it so im staying with it for now
Old Oct 1, 2005 | 03:35 PM
bcphatchback's Avatar
some shots of the engine apart to show the pistons and ect would be nice to see.
Old Oct 1, 2005 | 03:45 PM
b18CrxSi91's Avatar
71.179.86.205
Default Re: (bcphatchback)
You should be able to see low 14's if you can drive.
Old Oct 1, 2005 | 04:02 PM
I just got the digital camera.. No pics of the pistons. I can show you cylinder compression though 240 to 250 psi on all 4 cylinders
Old Oct 1, 2005 | 04:07 PM
kulangot's Avatar
i bet its fun to drive...
Old Oct 1, 2005 | 04:11 PM
because i had the head shaved i need adjustable cam gears to get the timing right but other than that its good
Old Oct 1, 2005 | 04:28 PM
trrbl1bmx's Avatar
you got the distribution block for your battery relocation in the same place i have mine. thats cool up. about to do a similar setup on my ef hatch
Old Oct 1, 2005 | 06:12 PM
Default Re: (ilovemyef9)
sweet how is the high end power?
Old Oct 1, 2005 | 07:23 PM
I'll have some cam gears in soon, so i will be going to the track with it.. Might be in a couple weeks but i will post times
http://www.autocarparts.com/part/1325/2
Old Oct 1, 2005 | 09:39 PM
4DRmafia's Avatar
i need get me a swap ....is that obd0 motor?
Old Oct 1, 2005 | 10:12 PM
Default Re: (SkipMic2006)
95 B18b1 OBD1
Old Oct 2, 2005 | 08:43 AM
ek9 ferio
10
Feb 16, 2006 07:59 PM
kid-crx
Apr 27, 2005 05:49 PM
NightHawkC5
Dec 12, 2002 09:21 AM
B20LS-T
Feb 20, 2002 08:16 AM
Nebula
Jan 10, 2002 08:20 PM
