gettin tuned
alright im gettin tuned on monday(oct 3) and i was talkin to my tuner and he said it should be around 320whp...does that sound about right for this setup?
last years set up..
b16a2
drag gen III turbo kit
440cc injectors
hondata s200
apexi N1 exhaust(cat..2.5inch dp)
8psi 222whp 165tq
this year
precision sc50 .63ar .69 trim
golden eagle sleeves(83mm)
arias pistons 9:1 (83mm)
eagle rods
3inch mandrel bent exhaust(no cat)
RC650cc injectors
act xtss clutch
gsr cams
aem fpr
aem fuel rail
i was hoping to make alittle more than 320whp
what u guys think?
last years set up..
b16a2
440cc injectors
hondata s200
8psi 222whp 165tq
this year
eagle rods
RC650cc injectors
act xtss clutch
gsr cams
aem fpr
aem fuel rail
what u guys think?
You could make what a stock B16 would make actually if you leave the wastegate open. I don't honestly think you are doing that (duh) haha. What I am getting at is you didn't specify how much boost you will be running on that turbo.
i told him 15psi but he said i could run more if i wanted to..i wanna run the highest psi i can and still be safe cause this is a street car and dont wanna blow anything up. i thougth i could make around 350whp on a good tune
I'm not sure what that turbo is rated at as far as efficiency....but typically I would try to stay around 18-20psi on pump gas. That's another thing I would look up, make sure you don't turn the boost up past its efficieny range or try and run way more whp than its rated at.
the turbo says 450hp...so it would be safe to run like 19 psi on pump gas daily drivin? i thought that might be to high..i just want the most whp i can get and still be safe..thats y i sleeved my block cause my car only has 51k miles and i want it to last awhile.thanks again for your help
Yeah you should have way more than 320hp, easy. I had 317whp @ 12psi on my LS/Vtec, stock sleeves, 450cc injectors, Hondata s100... Your setup is way better than mine, Id say about 400whp, with your setup. Your tuner either doesnt do many hondas, or he just sucks
Try to find someone else, it will be worth it to have someone with vouches do it-- even if it costs more.
well from my experience and what i hear hes a great tuner, well ls/vtec will make alot more power than my b16, i know hes a safe tuner maybe thats the reason y the power wont be very high...but i thought for sure it would be over 320whp..its gettin tuned tomorrow!! so i will let u guys know
Oh, I was thinkin it was a B18C. You should still have like at least 375, you could tune it to the max to see what it can do, then tune it down a little for safety. Plus you will get a cool dyno chart that says you have more power than you actually do
Let us know how it turns out. Good luck too
yea im gonna tell him to tune it at like 18 or 19 psi....ill see what happens..still hoping for 350 but i know its not gonna happen from what hes tellin me. but yea i will see..ill let u guys know
that doesnt seem right??? I wanna see the dyno sheet, somethings weird
Look at my dyno, im only 8 less hp with 6 less psi, that doesnt make sense, the extra .2 liters isnt that big of a damn difference.
Mine: https://honda-tech.com/zerothread?id=1373014
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ochsy03 »</TD></TR><TR><TD CLASS="quote">yea it feels fast as hell but traction sucks in 1st and 2nd..yea ill post it up alittle later</TD></TR></TABLE>
Oh yeah, I dont get traction at all anymore. I bet im gonna have to get used to the track all over again before I run a better time. I just ordered one of the ball bearing center sections for my turbo too, so its gonna get worse. Were gonna have to invest in some slicks soon arent we?
