feed my b20 more fuel!!!
why am i running lean still. my AEM FPR is at 40psi, i have stock b20 with mild head work done. when i rasie it up im was backfiring at high rpm... any tips??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">the inpection station told i was !</TD></TR></TABLE>
One option would be to find a crv manual ecu if you are obd2 that is.
A better one would be to chip your ecu and tune it with uberdata. I wouldn't think that it's that much of a difference between the LS and the b20 ecu with the 0.2 litre and considering the stock ls has a higher comp. ratio than the b20b.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bemorfast »</TD></TR><TR><TD CLASS="quote">what ecu are you using?</TD></TR></TABLE>
Kenji ecu for my B20 12.5:1
FPR allows you to raise the pressure at which fuel can reach in the system before being purged out.
Bigger injectors - common sense really.
Pump - supplying the fuel from your tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun »</TD></TR><TR><TD CLASS="quote">FPR allows you to raise the pressure at which fuel can reach in the system before being purged out.
Pump - supplying the fuel from your tank.</TD></TR></TABLE> so what should i get next?
lowRIDAH
12
Nov 25, 2005 07:56 AM
