Brake Caliper Rebuild Question - Help Needed!
Old Oct 1, 2005 | 08:38 AM
Flux's Avatar
Default Brake Caliper Rebuild Question - Help Needed!
I am in the process of rebuilding my calipers on my ITR. I havethe o-ring in place and the dust boot seated within the caliper but I have having some difficulty getting the piston into the caliper past the dust boot. The top opening for the dust boot is smaller than the diameter of the piston and I jsut don't see how to get the piston through there.
Any help would be greatly appreciated. Thanks.
Old Oct 1, 2005 | 01:39 PM
FIGARILA's Avatar
Default Re: Brake Caliper Rebuild Question - Help Needed! (Flux)
i can help you out, but before we get started your going to need some caliper rebuild lube (3$). Do not use high temp grease inside the boot as lube. A wire coat hanger will help as well. Im assuming you mean the fronts.
Old Oct 1, 2005 | 02:32 PM
Flux's Avatar
Default Re: Brake Caliper Rebuild Question - Help Needed! (Heron of Alexandria)
Thanks, I was able to get it finally. I used the lube that came with the rebuild kit.
Old Oct 1, 2005 | 02:47 PM
FIGARILA's Avatar
cool
Str8 outta Cliff
Suspension & Brakes
Jul 22, 2009 03:28 PM
Flux
Mar 10, 2007 08:05 PM
ROOROWNS
Jun 2, 2005 08:55 PM
rasinhell
Mar 7, 2005 06:09 AM
BrandonClaps
Sep 20, 2004 09:54 PM
