Where does it look like this oil is coming from...
Old Oct 1, 2005 | 06:08 AM
BoostinEJ1's Avatar
Default Where does it look like this oil is coming from...
First off the motor is a JDM B16a if that makes a difference... I can't tell if its the cam seal or if its one of the gaskets or filters in the assemblely that the VTEC solenoid is on top of (don't know exactly what that is called). The car did through a code 21 the other day which was VTEC spool solenoid valve... Thanks.
Old Oct 1, 2005 | 06:30 AM
Urban Camo's Avatar
Default Re: Where does it look like this oil is coming from... (slowsinglecam)
cam seal
Old Oct 1, 2005 | 08:25 AM
elitesi8's Avatar
Default Re: Where does it look like this oil is coming from... (Urban Camo)
You ned this!
Old Oct 1, 2005 | 08:27 AM
Luserkid's Avatar
Default Re: Where does it look like this oil is coming from... (elitesi8)
Yep its your cam seal. Just get a new one there not that much.
Old Oct 1, 2005 | 08:28 AM
BoostinEJ1's Avatar
yea i bought a new cam seal and valve cover gasket. i still don't know why it would throw a code 21 though. maybe just the wiring.
Old Oct 1, 2005 | 08:30 AM
Luserkid's Avatar
Did you reset the ecu?
Old Oct 1, 2005 | 08:53 AM
gutted-dx's Avatar
How much are the eagle cam seals
Old Oct 1, 2005 | 10:04 AM
BoostinEJ1's Avatar
Old Oct 1, 2005 | 10:29 AM
93civic_sedan's Avatar
Default Re: (slowsinglecam)
I had an STR cam seal on my b16 in my CRX it was nice got it for like 30bucks.
Old Oct 1, 2005 | 06:10 PM
T.J.'s Avatar
its coming from the cam seal , and know you do not need one from golden eagle. Oem will work just fine with proper installment.
Old Oct 1, 2005 | 06:15 PM
_gurusan_'s Avatar
Default Re: Where does it look like this oil is coming from... (T.J.)
I got an STR cam seal for like 20 or 30 on ebay.
Even just a no-name brand is better than OEM. OEM cam seals have only 1 ring thingy...while most aftermarket ones have 2 or more.
OEM cam seals are always leaky bastard.s
Old Oct 1, 2005 | 06:39 PM
eg crunkmonster's Avatar
Default Re: Where does it look like this oil is coming from... (_gurusan_)
get an OEM one, those golden eagle and other ones are a bitch in the *** to put in because you have to pull away the cam caps and crap. oem one pops right in
Old Oct 1, 2005 | 07:52 PM
_gurusan_'s Avatar
Default Re: Where does it look like this oil is coming from... (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">get an OEM one, those golden eagle and other ones are a bitch in the *** to put in because you have to pull away the cam caps and crap. oem one pops right in</TD></TR></TABLE>
You have to remove the cam caps? You sure? argh.
Old Oct 1, 2005 | 08:02 PM
yup, just get an OEM one, u just have to unbolt the vtec selinoid and take off the old one and pop in the new one
Out of every "game"
Apr 16, 2006 02:41 PM
Out of every "game"
Apr 16, 2006 02:14 PM
JimBlake
Mar 1, 2004 01:22 PM
vtec69
Jan 10, 2003 04:56 PM
