TPS sensor replacement for Pre OBD B16A
Yes, you can use almost any Civic/Integra TPS sensor. I'm not sure which other ones will work. But, for reference, I used an 88 HF TPS sensor on my b18c1.
If you have the original TPS sensor, it will probably be riveted on. You can take a dremel and cut slots into the rivets, and unscrew it with a flathead screwdriver.
Then, install your new TPS and make sure you calibrate it to factory specs (0.5v closed, 4.5v at WOT) before tightening the bolts down.
lol easier said then done.i read on a site a dont know if it is tru por not but they were saying its almost impossible it get the tps back top honda specs.can be done but its a pain in the ***.
eghonda1320
Sep 12, 2008 03:30 PM
EFRue57
Sep 17, 2005 05:41 PM
b16, b16a, bolts, crx, element, honda, installation, installing, replace, replacement, replacing, sensor, specs, tp, tps
