b20vtec or b20 turbo
what would you do i drop in a jdm b20b in my 91 teg
would you drop in a vtec head
or do a turbo
both put out the about same h/p
both have flaws if not done right.
tell me what you would do
or do a turbo
if you want to beat honda's go b20vtec
if you have a change at beating anything else out there go turbo ls. (I wouldnt trust the b20 walls) . For the full potential of the ls, mild build the head, stock I would rate a D+.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finger Lickin’ good »</TD></TR><TR><TD CLASS="quote">if you want to beat honda's go b20vtec
if you have a change at beating anything else out there go turbo ls. (I wouldnt trust the b20 walls) . For the full potential of the ls, mild build the head, stock I would rate a D+.</TD></TR></TABLE>....ya, the walls little thin on the b20...i would just go NA... i got a b20vtec, and loving it.... i raced at turbocharged civic....and i was just ahead of him....NA, and loving it...full throttle response...but u can b20 turbo, u just gotta reselve...so i dk... my opion, b20vtec is whats best for ur setup..but if u had an LS, be diff. story
b20 turbo would probably be a lot more money considering you'd have to resleeve the motor. i'm not so sure about a b20-vtec nd b20 turbo putting out the same power though...
