stripped lug nut/studd.
Old Sep 30, 2005 | 03:05 PM
AZTEKEF9's Avatar
Default stripped lug nut/studd.
well i had a flat the other day.....i replaced it with a spare. i notice that 2 of the nuts where kinda hard to tight them but i managed. got a ney tire put on the rim replace it and again those 2 nut where kind of hard...so when i tries to take them out to replace them they where stuck. i tried to put as much force to brake them...but instead the studd started to spin...so now i cant take the rim off. the studd got striped on the hub. how can i take the rim or brake the studds???
Old Sep 30, 2005 | 04:31 PM
CRX Toad's Avatar
Default Re: stripped lug nut/studd. (AZTEKEF9)
Wow...that sucks man. Disc or drum brakes? You could try getting a nut breaker and going at it or a dremel.
Old Sep 30, 2005 | 04:43 PM
AZTEKEF9's Avatar
Default Re: stripped lug nut/studd. (CRX Toad)
its actually the front left. and i don't want to damage the rim.....another thing is it uses tunner nuts....so the hole is pretty small.... i already chipped the holes a bit.
Old Sep 30, 2005 | 05:53 PM
shawn_crx's Avatar
The only thing i could think off, is drill the nut off and hit it with a rubber hammer to break the nut off the stud.
Old Sep 30, 2005 | 05:54 PM
vtecn8ive's Avatar
pics?
so you are trying to get it off or put it back on? is it stuck in one spot and immobile?
Old Sep 30, 2005 | 06:25 PM
AZTEKEF9's Avatar
Default Re: stripped lug nut/studd. (vtecn8ive)
i need to het the nut and the studd off...i don't want to drive like this....and i already try to drill it out....whent to the hardware store and spend 40 on drill bits....and nothing...try to hammer it out....amd i damaged the rim...that was the last thing i waned to do....damage the rim.
Old Sep 30, 2005 | 06:41 PM
d16efsedan's Avatar
i had the same problem.i took a flat head screwdriver and wedged it behind the head of the wheel stud and took the lugnut off that way.hope that helps a little.
Old Sep 30, 2005 | 06:47 PM
EL Vap133's Avatar
Holy crap that sucks!!!
Old Sep 30, 2005 | 06:49 PM
vtecn8ive's Avatar
you are supppose to take off the hub assembly. if you have a puller it easy.
Old Oct 2, 2005 | 01:18 PM
AZTEKEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">you are supppose to take off the hub assembly. if you have a puller it easy.</TD></TR></TABLE>
well the hub assembly is out. but how do i manage to take the nuts
Old Oct 2, 2005 | 10:15 PM
vtecn8ive's Avatar
try to apply pressure and tighten and then back off by trying to loosen if nothing works. time to cut it off. maybe use some heat.
=shane
Old Oct 3, 2005 | 01:15 PM
AZTEKEF9's Avatar
well i tryed to drill out the studd...but after $45 worth of drill bits...nothing . and the rims got damaged where the nuts go. man, i thing i might take it to a machine shop and have them drill it out.
Old Oct 3, 2005 | 01:25 PM
BioXide02's Avatar
lol, this problem SUCKS.. It happen on one of my CRX's.. I ended up just using a dremel with a good bit on it to just grind away on the lug nut. Thats the only way I could end up taking this thing out.. I even tried using an air chizzle to try to make the lug nut split in half, but that didn't work at all and I ended up messing up my wheel
Old Oct 3, 2005 | 01:31 PM
AZTEKEF9's Avatar
Default Re: stripped lug nut/studd. (BioXide02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 &raquo;</TD></TR><TR><TD CLASS="quote">lol, this problem SUCKS.. It happen on one of my CRX's.. I ended up just using a dremel with a good bit on it to just grind away on the lug nut. Thats the only way I could end up taking this thing out.. I even tried using an air chizzle to try to make the lug nut split in half, but that didn't work at all and I ended up messing up my wheel </TD></TR></TABLE>
the prob is that the holes in the rim are very small, they only take the tuner nuts...that why i'm having a hard time geting to it...
Old Oct 3, 2005 | 01:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
When it happened on my car, the mechanic used an air tool with a socket on the lug nut, and turned up the torque, to break the stud. Then the mechanic used a hammer to pound the broken stud from the front & out the back of the hub.
No damage to the wheel.
Homotor
Feb 20, 2009 12:29 PM
l3 o r e d
Nov 15, 2006 06:38 AM
koolkevin1107
12
Nov 11, 2005 04:45 AM
user 996328629
Jun 5, 2004 05:53 PM
DeLiRiOu5
Jan 22, 2004 09:50 AM
