antenna install on em1?
Old Sep 30, 2005 | 01:30 PM
bunks99si's Avatar
Default antenna install on em1?
ok so here is the deal, i pulled the old antenna out, now im stuck as to find a way to fish the new antenna through the hole. is there any trick to this or what? i already searched really couldnt find anything. thanks in advance.
Old Sep 30, 2005 | 02:04 PM
Echo7847's Avatar
Default Re: antenna install on em1? (bunks99si)
It wouldve helped if you had tied a string around the old one before you pulled it out.
Just snake it down the a-pillar under the dash and plug it into your sub lead.
You're on your own with this one.
Old Sep 30, 2005 | 03:10 PM
JDM-EJ1's Avatar
Default Re: antenna install on em1? (Echo7847)
It's going to be a real pain to do. My best advice is to just snake it down there and attack it to the plug in.. Good luck.
Old Sep 30, 2005 | 03:16 PM
graveltravel's Avatar
this is what i did.
get an antenna block off plate.
install the antenna to the radio, and find a place behind the dash to hide it.
i did mine like that in my ej1, and i still pick up my radio signals fine. just cover all metal pieces up in the antenna with electric tape or whatever to keep from haveing road noise.
Old Sep 30, 2005 | 03:24 PM
bunks99si's Avatar
i took an old fish tape thingy and chopped off the hook on the end. then i just pushed it up from under my dash and was able to pull the antenna back down. wasnt too hard lol
austinwith96civic
Mar 11, 2010 09:49 AM
4gen5thtime
Mar 15, 2009 10:40 AM
awwsnap
Aug 21, 2005 08:00 AM
bmw626
Jun 6, 2005 02:49 PM
mattL
Nov 5, 2002 02:53 PM
