no brake pressure and loosing brake fuid please help
Old Sep 30, 2005 | 12:44 PM
CivicHP's Avatar
Default no brake pressure and loosing brake fuid please help
i have no brake pressure when i apply brakes the pedal goes to the floor and then it start to brake. i checked my fluid level and it jus above min last time i checked was about 2 monts ago and it was near max line. checked everywhere under booster nothing no paint chipping also cecked prop valve nothing there to. what the problem master cylinder,booster, brake lines or caliper piston seal?
Old Sep 30, 2005 | 12:51 PM
jameskersten1's Avatar
Default Re: no brake pressure and loosing brake fuid please help (CivicHP)
sounds like your master might be by-passing internally but I dont know if that would account for the lost of fluid
Old Sep 30, 2005 | 01:28 PM
Luserkid's Avatar
Default Re: no brake pressure and loosing brake fuid please help (jameskersten1)
Bleed the brakes and see if that fixes it.
Old Sep 30, 2005 | 01:32 PM
RedEj8's Avatar
Default Re: no brake pressure and loosing brake fuid please help (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Bleed the brakes and see if that fixes it. </TD></TR></TABLE>
riceburnerryan's Avatar
afte bleeding the brakes.. check if there is any fluid on the ground ... just a thought
hteg12
Jul 18, 2013 05:13 PM
Chilloutdamn
Nov 4, 2008 03:24 AM
UltimX
21
Feb 8, 2006 08:29 PM
H.crx-si
Jul 6, 2003 10:05 AM
dnt94civic
Jun 7, 2002 05:04 AM
