Problem on my skunk 2 intake mani install
so its all hooked up. i broke the knock sensor but people said that isnt a problem.no vacuum leaks and it starts and idles fine. when i hit the gas it bogs down. any help??
its a obd-1 gsr btw
its a obd-1 gsr btw
vehicle spec's?
obd1 gsr
with
skunk2 im
and....
if this is all that is done to the vehicle, no cams and such you will enjoy this wonderful bog since vtec is engaging too early.
please explain where the bog is happening.
general post like this suck.
obd1 gsr
with
skunk2 im
and....
First thing to do is to make it sound and that's by replacing the knock sensor. That way you can rule it out instead of going on what you've heard from other people. I mean the car ran fine before the IM install right? Should still run fine afterwards, with the exception of the early VTEC bog at 4500.
maybe your swap the tps and map sensor. I did that before and my car cranks but when I give it gas, it dies on me. Found out I had my tps plug in the map vice versa. Both those plugs fit eachother...try that and see. I would fix the knock sensor though just to eliminate all possible problems..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkZeroNine »</TD></TR><TR><TD CLASS="quote">i assume that was my problem. but now my car hasnt been starting. i found out that the ecu fuse keeps blowing.......</TD></TR></TABLE>
you probaly have a short somewhere....wires touching something inorder for the fuse to keep blowing....
I just put on my Blox intake manifold last week, I broke the knock sensor as well. Safe to say its not cheap to replace, 150 bucks from acura
not cheap at ******* all!!!!!!!!! anyway, are you gonna replace it? i have no plan to replace mine. can't justify 150 on a sensor if it dosnt do anything. but im a broke college kid, if you can afford it more power to you
I replaced it, why wouldn't I? No sense leaving a broke sensor to cause problems later on. Safe to say my bank account is pretty empty right now, I feel your pain with the broke college student part. =P
