Anyone ever heard you can default your timing by removing your hazard fuse and disconnect your batte
Old Sep 30, 2005 | 11:19 AM
Jonovision's Avatar
Default Anyone ever heard you can default your timing by removing your hazard fuse and disconnect your batte
If so,whats the procedure?
Old Sep 30, 2005 | 11:22 AM
Luserkid's Avatar
Default Re: Anyone ever heard you can default your timing by removing your hazard fuse and disconnect your b
What do you mean default your timing?
Old Sep 30, 2005 | 11:24 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean default your timing? </TD></TR></TABLE>
I think he means default as back to stock? Theres no way that will work...I don't think
Old Sep 30, 2005 | 11:35 AM
Relic1's Avatar
removing the battery terminal resets the ECU, it doesn't change the ignition timing.
It may change how the car runs if there is a code set or if it ran with poor fuel for a while, but it will not change the base setting for the ignition timing.
Old Sep 30, 2005 | 05:55 PM
spoonsports12's Avatar
what u talkin about willis
Old Sep 30, 2005 | 07:16 PM
Do_Ster's Avatar
if i understand your question correctly, it is impossible to have the timing go back to factory default just by simply removing a fuse and disconnecting your battery. you'd need a manual and have to adjust your dizzy. the ECU will reset itself to default but will recalibrate after i believe some odd miles of driving.
ONE.SIX SI
Nov 27, 2004 04:00 PM
aron0903
Aug 4, 2004 12:34 AM
Daniel
Aug 22, 2003 07:05 PM
VSM EXtasy
Jul 19, 2003 10:19 AM
